Most definitely.If you can afford 2.5tdi with aircon buy one,the difference is worthat every penny and you will have yours money back when you sell.
Nothing wrong with the 2.4D. As with any vehicle it's more than likely up to the job as long as it has been looked after. These can be boosted with aftermarket turbos. I'm not sure by how much and whether it's worth the extra expense. Beyond the engine considerations though you want to find something that's got solid and original bodywork. The T4 can be prone to rust on wheel arches and some seams. As a one time T25 owner you'll probably know the kind of thing.
Thanks for the advice.You'll find a bunch of T4 owners on the forum take T4s on road trips to France. Myself included. Any T4 Westy would be capable of such a journey regardless of engine size as long as it was well maintained. Ultimately it comes down to your expectations of the vehicle. The 2.4D will require a bit of stirring in the gears if you head to the Alps or other mountainous region. The 2.5 - 102 or 150bhp still like to rev when climbing stuff but will cruise more effortlessly. Realistically it comes down to your budget at the end of the day.
Not sure what the setup on the earlier bench seat belts is but our 2001 has three point belts for both passengers. Based on this I would imagine it's possible.That's great the 2.4's are good on long hauls!
Has anybody manage to replace lap belt on the bench seat to a 3 point seat belt?
Ive got two young children who need car seats.
Thanks for the advice!I agree, it could work; you could check it out on a younger t4 westfalia vehicle. The place where you fasten the belt above, is in the high closet. The belt does come through the cupboard above the bench and therefore it could mean that you have to make a cut-out in that closet.
I think from 1995 (cactus pattern upholstery) the rear seat bench usual has two three point automatic safety belts. Before: some do have two 3 point seat belts... but certainly not all.
I don't know if anyone here did this transformation before. We travel with an almost 3 years old girl and until now, one 3 point seat belt is sufficient
Greetings
Calibusje
