itscalledbob
Home is where you park it
I have an unused 2kw generator for sale.
Purchased about 18months ago and have never used it. £540 new
£400
Collection from PE73WH
The Senci SC2000i Inverter Generator with Yamaha MZ80 engine ensures this is the most reliable camping and caravan generator available on the market. All Senci Generators are made with the latest EURO V Emission standard engines.
Yamaha are known as one of the leading manufacturer of quality engines and together with Senci's design and technology, the SC2000i brings the best features from both companies. Highly reliable machine producing a maximum power output of 2kw with a noise rating as little as 50dba.
£400
- Coupled with superior quality Senci inverter alternator.
- Super quiet, operates at 50–65dba with noise reduction system.
- Advance inverter technology delivers reliable power for computers and other sensitive electric devices.
- Low oil alert protects the generator when low oil is detected.
- Thermal breaker protects the generator from being overloaded.
- Auto throttle varies engine speed based on load and keeps the noise down.
- Choke knob convenient for cold start.
- 3 in 1 indicator indicates output, low oil alarm and overload alarm.
- Fuel petcock prevents carburettor contamination during storage.
- Lightweight compact design that's easy to carry and operate.
Model | SC2000i |
Engine | Yamaha MZ80 |
Fuel Type | Petrol |
Starting System | Recoil Start |
Displacement | 79cc |
Compression Ratio | 8.0:1 |
Frequency | 50Hz |
Rated Power | 1.6KW |
Maximum Power | 2KW |
Sockets | 1 x 230v 13a, 1 x 12v 8a DC |
Fuel Capacity | 4L |
Run Time | 6 Hours + 50% Load |
Noise Level | 58dBA + 7m |
Dimensions | 540 x 330 x 505mm |
Weight | 22kg |
