Agnes
Hi. Fuel panic. Can I get diesel out of the cali to put in my car? I have 400 mile trip to do in the car and need some backup. Is siphoning possible? And if so how!
You can buy simple siphon pumps from places like screwfix to put into the line to avoid any fuel ingestion.The siphoning theory is straightforward- poke a tube in the tank, suck on the pipe and when it starts to flow drop the end into a receptacle (lower than the end of the pipe in the tank). Diesel doesn’t taste as good as petrol so if you use a clear tube you can cut the suction when the fluid nears the end. Some cars have baffles and the like in tanks which can cause a problem getting the tube down - not tried on the Cali. Used to do it all the time with me mum’s car when I was a kid so I could fuel my scrambler.
Thanks. I thought this might be the case!
