i seem to smell of toilet mix stuff by thetford , have not used new loo but i seem to smell of the stuff like it gets in pores of skin a bit of nausea ?
hi i empty it i think i used to much flush pink stuff as its not air sealed i guess it could be that many thanksShould not smell at all. Is there a problem with the seal on the lower part of the thetford?
Try with less liquid or dilute with water.
think it was the flush mixture that is the strong smell guessing that's easy enough too remedy many thanks MarkIt’s a vile pungent smell ... you prob used too much but the smell should change once you start filling it. Keep it in your kitchen cupboard: should be fine in there!
had about 3 litres of pink flush rolling about on top don't think that's air sealed its probably that many many thanks i am still smelling of the stuff .How much did you use and did you pour it into the waste tank?
Were you using it neat? You do realise it’s about a cupful per flush tank. (Refer to manufacturers instructions).had about 3 litres of pink flush rolling about on top don't think that's air sealed its probably that many many thanks i am still smelling of the stuff .
used the recommended amount i did put in waste tank though , may be the flush ? stuffHow much did you use and did you pour it into the waste tank?
Yeah I was referring to the pink flush liquid.used the recommended amount i did put in waste tank though , may be the flush ? stuff
If you’ve used 100 ml per 3 litres of water you should not be smelling of it or feeling nauseous.yes just might have over done it a little with flush and a mount 3 litres water and 100mls of flush
it was a bout 3 weeks old .If you’ve used 100 ml per 3 litres of water you should not be smelling of it or feeling nauseous.
think i will use a sprayer for the flush mix and keep all well sealed cheers Mark.If you’ve used 100 ml per 3 litres of water you should not be smelling of it or feeling nauseous.
Done Plenty of that usually with a pit chemical is luxury if get used to biological well fairI love the smell of toilet chemicals, it makes you feel like you are camping
will try i emptied the flush good clean out and just put in waste water and green pod and sprayed silicon stuff on rubber make sure no oder coming back air tight container many thanks will try the Zoflurea to humid to be wearing a NBC suit in van cheers MarkWe use a bit of zoflura in the flush it tends to smell a lot nicer..But there are lots of toilet chemicals on the market we buy the Aldi one and it’s really not to strong smelling..
Reminds me of scout camp.I love the smell of toilet chemicals, it makes you feel like you are camping
