Solar dilemma
Jackpine
Earby
Looking to buy
Hi,
Not had my Cali SE long, it came with a Cali topper and a Khyam Cozi topper.
If I put solar on the roof these are no longer any use.
So do I do solar and Iso-top or something else.
Advice please.
Thanks in advance
Hi,
Advice please.
Thanks in advance
Go solar and Isotop. There is a market for the redundant kit.
can think of anywhere other than the sahara desert where you might need solar and cosy roof sock at the same time
A rainy FlĂĄm in June (photo).
Pyrenees in November.
Bulgaria and the Beast from the East.
Carpathians over Easter.
Corf Castle in stormy weather.
If you have it, you can use it. If you don’t have it you can’t.
It is also useful to keep the light out when the sun doesn’t set.
If it was a cloudy day in the Skanderberg foothills and i had an industrial sized sun lamp in the van i still dont think i would use it
If the weather is that bad that you require a Topper then the likelihood of getting any significant benefit from a Solar panel is probably minimal eg: Winter with heavy rain or snow for prolonged periods and wild camping.
Hi,
Advice please.
Thanks in advance
Are you sure you need solar?
We have managed 6 years so far & never felt the need. Unless you are parked up in one place for more than about 3 days without hookup & not moving you shouldn't need it unless the batteries are shot.
It is useful if you don’t have easy access to mains power at home, to keep the batteries fully charged.
In my experience. Solar is good for 3 things:
1) When you are parked up for a while at a site and need to keep the battery topped up to power the fridge. This is only needed when you do not have access to mains charging.
2) Keeping the battery topped up to extended life when the vehicle is parked up for long periods (say > 1 month).
3) Avoiding hook-up charges (but you this might mean you get a pitch that is not hard standing). In winter camps, you are probably on hook up anyway, to power the heater (depends on the heater type)
My conclusion was to fit a portable. I just place it on the bike rack, or roof if the roof is down when I need it. Usually, driving keeps charge topped up and I often use hook-ups. Solar keeps my battery fresh over winter months and is definitely useful at festivals, where hook up is rare and you need that beer to be cool.
Hope that helps.
Hope that helps.
Thanks yes it helps
Hope that helps.
Yes the portable option is a good idea. Especially if you cannot get your solar panels in the right direction.
I have opted for a roof mounted solar panel that I can quickly take down and plug in with a longer lead to catch the sun. It also is less to carry inside.
Hi,
What type of roof mounted one do you have?
K
66tim99
66tim99
Gelato
10K
California_Ocean
California_Ocean
Monty-Wilf bus
Roger Donoghue
Roger Donoghue
GrumpyGranddad
6K
markanichols
markanichols
V
Amarillo
Amarillo
