Thanks, that would be really helpful. Its the bottom bracket. Have had some problems with the electric closure suddenly opening and see now that the screw holding the door to the bracket is scraping as the door gets pulled in just before it’s fully closed. The screw protrudes under the bracket by about 3mm so I want to loosen it up to test it. If this works I figure I can just stick a washer on the top so it doesn’t poke out under the bracket so muchHmm, might even be M10, not really sure about that. Might check it tomorrow. What arm do you mean? the middle, top or bottom?
But M8 you might need when a door lock fails.
Yep, must be M8.
