bxl_lad
Its not easy being green...
My next project in the van is to sort out the audio setup. The previous owners in their ‘wisdom’, fitted a fancy Alpine stereo and installed some rather garish boy-racer type amps and screwed them to the side of the kitchen unit (this incidentally means the drivers seat no longer swivels around! – my main gripe!). I feel this installation is unnecessary and will unstitch it all (which will be a job in itself as you should see the amount of cable running around for this!) and replace with a more ‘traditional’ setup… But this leads me to a few questions (Any advice on these points will be greatly appreciated):
- Rear speakers in the overhead cubby: Were these a standard fitting to all 1999/2000 T4 Cali’s? There are speakers there now from the last owner’s intervention, but for sure the cable running to them is not the factory fitted cable and in the brown ISO plug in the dash there are only connections for the front speakers (only two pairs) – see pic. The cable they added only reaches the amps behind the drivers seat.
I can of course extend these to the radio slot in the dash – presumably its just a case of adding these into the brown ISO plug and connecting them to the new head unit?
(Incidentally, I will replace the Alpine with something a little newer so as to give the ability to USB/SD based music).
- If I put a standard radio into the dash (and lose the additional amps) – any advice on what kind of power output I need to be looking for in order to drive all the speakers in the van?
- On the subject of speakers – There are speakers in the front Doors and on the Dash – how should these be wired into the ‘to be’ traditional setup? Are they both considered as ‘fronts’ (the brown block has only slots for 4 pairs, not 6 speakers as there would ultimately be) – or is there some trick to wiring these (presume the door and dash speakers are different types?).
Also – the dash mount speakers – I can remove the grills, but there appears to be no screws holding in the speakers themselves – are these just a force fit and need to be pried out? Or is there another trick?
- Finally (I think!) – Seems the standard radio is powered by the traditional ‘van’ battery and not the leisure battery… This means then that the key should be in the ignition. Has anyone powered their radio from the leisure battery – any tips/tricks? Good or bad idea?
