HIDo you get the noise of the motor pulling it in? If you give it a shove does it close fully?
Thats a good tip from Belgium.If the motor does not pull de door tight give the contacts a clean .
Do you see your sliding door open on the dashboard? Do the lights go out when you put on the ignition?
