Soton Campers
Southampton Campers
Trade Advertiser
Hi all. After some advice please. I need to install an electrical device and after removing the hatch for the leisure battery in the bottom of the cupboard and having a look around I could see that the wires to the water tank sender unit look easy to splice into. I just need a permanent live. Would this be ok tapping into this I should I do it direct from the leisure battery terminals? If I do need to disconnect the leisure battery, is there anything I need to do before hand? I wouldn't want to cause a fault or anything!
