Are you mad!Somewhat related - I was disappointed to find the none of the USB plugs will charge an iPad. Phones are OK, but when driving, running a cable from the inverter socket to an iPad for GPS is a bit of a pain... Maybe some new (larger) phones also draw too much power for the USBs? We use car play and a phone for Navigation, but co-pilot is often looking at more detail on the iPad.
The standard USB socket WILL charge an iPad, just more slowly and without the Charge icon showing. It will charge sufficiently to keep up with using it and will certainly charge from 20% to 100% overnight. At least mine does.Somewhat related - I was disappointed to find the none of the USB plugs will charge an iPad. Phones are OK, but when driving, running a cable from the inverter socket to an iPad for GPS is a bit of a pain... Maybe some new (larger) phones also draw too much power for the USBs? We use car play and a phone for Navigation, but co-pilot is often looking at more detail on the iPad.
Why not fit a multi USB extension to the kitchen 12v socket via a plug. They now come with iPhone and standard USB sockets.
https://www.amazon.co.uk/dp/B06XY27X2G/?tag=eliteelect-21
Kitchen unit, Cup holder by sliding door and Boot 12v sockets run off the Leisure Battery along with the Inverter. Dashboard/Cigarette Lighter socket runs off the Engine Battery.Thanks, good tips. The iPad pro 12 in. battery percentage just goes down when plugged into the USBs....
I ordered the small 30W adapter for now. BTW, can someone please clarify which plugs run off which batteries? Assuming the inverter is on leisure but the two 12 sockets?
