OldSpeckledBen
Black VW mattress that came with dealer-bought 3 seat 2020 VW California Beach. Barely used and replaced with blow up mats to take up less space in the van. £300 - collection from Bristol.
Width 147cm.
Overall length 197cm, made up of 3 sections. First section (shaped to fit into rear door) is around 81cm long and then the next two sections are each around 58cm long.
The first section (shaped to fit into rear door) is deeper at around 9cm. The other two sections are around 5cm deep. The difference in depth is to accommodate the height difference between the multiflex board and the rear bench seat when folded out flat, so that you end up with a flat sleeping surface.
Width 147cm.
