Accessories For Sale Sold . Wardrobe shelves yes campervan
flying banana
flying banana
T6 Ocean 204ps manual
doncaster
T6 Ocean 204
Set of 3 shelves for the t6 or se without safe. With instructions. You may need new double sided tape but ii think the old tape is good enough as the shelves once in hold themselves up. They may not fit 6.1 due to different door design. I had these in my t6 but I just don't like them. One shelf is scratched on surface but i would recommend non slip matting anyway. They are 230 quid new.
Accept 100 cash on collection or 120 with postage and boxing up to UK. Can also take to camperjam or busfest for collection.or you can collect Sheffield Station where I work or my gaff in DN8 area. Also visiting yorkshire dales this weekend and buttermere weekend after if someone wants to organise collection around there.
If you didn’t fit the bottom shelf could you fit in a Cali with the safe fitted or does the bracket go into where the safe is fitted?
I can't remember. I'll have to check tomorrow. I'm.assuming it goes to the bottom so with the safe it would be shorter. Could easily be cut down. i've had a quick look and the supports go right to the bottom of the wardrobe ,where the safe would be in your case they would be too long.they sort of 'stand' on the floor of the wardrobe and just stick to the walls with tape
100 with postage. Or 90 on collection
So these will need the brackets cutting down to fit a Cali with the safe then? Are the shelve heights adjustable?
