P
Patrick Thomas
Patrick Thomas
I have problems with my T5 California warning lights, ABS Tire Pressure coming on, have checked but lights still come on. Has anyone any idea how to correct this? patrick.thomas251@+++++.com
Could you confirm - you have the Tyre Pressure Warning light On? If the tyre pressures are OK, have you Reset the Tyre Pressure Monitor on the MFD?I have problems with my T5 California warning lights, ABS Tire Pressure coming on, have checked but lights still come on. Has anyone any idea how to correct this? patrick.thomas251@+++++.com
There is one little patch of the M6 Southbound just north of Stafford that triggers my TPM warning every time I travel that stretch.As above. Tyre pressures change with ambient temperature. They can then vary from the side of the vehicle in shade to the side in full sunlight and when driving you can then get pressure/volume changes varying from side to side that trigger an alarm. Resetting the Tyre Pressure Alarm gives it a new baseline to work from. This commonly occurs during seasonal temperature changes, especially if abrupt rather than gradual.
Exactly the same problem with my T5.I have problems with my T5 California warning lights, ABS Tire Pressure coming on, have checked but lights still come on. Has anyone any idea how to correct this? patrick.thomas251@+++++.com
Thats SKIDDY CAR SYMBOLExactly the same problem with my T5.
Did you manage to resolve it as most replies focus on the tyre pressure and reset required, I have ABS and the skinny car symbol up also all at the same time.
That is the ESP ( Electronic Stability Programme). Dependant on a working ABS system. Hopefully 1 or more ABS sensors failed and not the ABS Module, which is rare.Exactly the same problem with my T5.
It’s almost certainly an abs wheel sensor that’s gone bad. You will need an OBD 2 code reader to be certain which one it is. I’ve got a carista. It was about £25 on eBay with one month subscription free. Simple to use and pays for itself on first job. Exactly the same thing happened to me.Thats SKIDDY CAR SYMBOL
I have just had to have my tyre pressure reset on my T5. Lucky I was near a VW garage who did it for me but as I have had the problem before I thought it was time to make a note of what to do. I have found this youtube which may be of use to anyone else.Exactly the same problem with my T5.
