Water tank replacement
  • Thread starter samuelllllllllllllllllllll
  • Start date
prague
T6 Ocean 204
hi guys, I have bought used cali T6 ocean and I have to replace water tank (contaminated by diesel). I ordered all needed and cant find any workshop manual for camper installation :( could someone help me? Original VW servis is too expensive for such replacement. Also I want to understand whole camper system, another motivation to do it by myself.
Check out the Resources section of the Forum. There is a VW California tech manual on the camping side of things . Although for the T5 nothing changed until the T6.1. Might be of help.
Also the VW ERWIN site. You pay for timed access to the full workshop and Repair manuals for your particular vehicle based on the VIN number, but you can download the relevant sections/manuals as pdf files to view off line.
Was
Best of luck with this. Where are you based?
I used workshop manual posted above just to see how it looks like. I approached it as big Lego. Its worth, not all steps are in! I share my observations below ;)
Replace all shells, doors, table etc. What you can easily do. Then replace back seats, manual you can find on youtube, system is similar to any multivan T6. Open all covers inside, to see what is inside. After this we can start.
  1. Overhead storage compartment. Loudspeakers are glued! before you start use knife to replace glued cover and disconnect them
  2. Panels inside the cupboard, left one is glued
  3. Cupboard mounting points to the body, its easy to find it, beware one is under the car!
  4. Do not forget to waste pipe! It is situated next to fridge. Easy way is to unscrew pipe from outside.
  5. Unplug electricity, first batteries, then all components, everything is easily accessible and visible.
For disconnection water tank I used this post
Than you are free and can try to pul it out. Sorry guys I forgot to do photos :( I have only one
If you have any questions do not hesistate to contact me personally via email :)
Hi Samuel! I have the same problem with our T4 water tank (diesel in it), but really struggle where to buy a new one. I know you have T5, but I can't see any offer for those either. Where did you get the new parts from?
Thanks!
D
5K
GrannyJen
GrannyJen
secret lemonade drinker
Goingontour
Cali Phillip
Cali Phillip
Chris Bray
calikev
calikev
