Water tap on T5 California
D
David Bradley
The tap no longer fires up the pump. I have checked the fuse is Ok. When I lift the tap there is a faint click.
If I want to take the tap apart and clean up the micro-switch, how do I get the tap off safely?
Thanks anyone
If it tap clicks I would check the pump first they do stick.
Dealer replaced the water pump and all fine now. Thank you.
Seems like many new Cali's need to have a new fresh waterpump within the first year(s)
Mine was also replaced still under warranty , 1st year
How old is yours....?
Tap stopped working again .. pleased I had put in an electronic bypass switch to allow the water to still flow.
remove the wire fitting .. then add in my bypass switch . Then hey presto tap works … via a hifpdden switch .. enough to get it working while I order a new tap 6660040E-0CED-44F9-9B81-763C57688678.jpeg8B0CE6DC-2357-42A8-AFD6-614F6C12F70D.jpeg
  • Like
Reactions: Sad
Pure Worktop Protection
Paddy GC680
P
D
DNorthcroft
D
mountainman
mountainman
mountainman
