Will Devonport wheels definitely fit a 2022 build T6.1 Ocean 4Motion? Only asking as the 17” Amarok wheels that did fit my old T6 don’t fit the T6.1
WaikatoCalifornia
WaikatoCalifornia
New Zealand
T6.1 Ocean 199 4Motion
Hi all, I’m stuck in a bit of a bind, having upgraded from a T6 to T6.1. The wheels in the second photo fitted my 2016 build T6 Ocean 4Motion (180PS I think) perfectly, but I just tried them on my 2022 build T6.1 Ocean 4Motion (199 PS I think) and they don’t fit. There is enough diameter to accommodate the disc brake assembly, but they bolt on too snug to clear the caliper assembly. Will the Davenport wheels (which is what I believe the ones in the first photo are) fit,,does anyone know for sure? Looking to switch the A/T tyres off the other ones on to a new set of rims. Thank you.
Thats strange - I thought the brakes were the same size on 180s as 199s. are you sure you didnt leave a set of spacers on the hubs when you took the wheels off?
In answer to your question 17" Davenports should fit. If they don't its because someone has put oversized brakes on your new van....
