window blind keeps creeping up!
A pain in the arse.
Make sure it is locating on the cheap and nasty plastic door pillar. Most don't locate properly, slip out and raise up faster than my hemline in the 60's!
seems it was the heat? Behaving at the mo cos cooler!
If you look at the bottom of each slide groove there is a piece of metal to grip the blind slider. Squeeze it a bit tighter to grip.
