N
Nigel hawkes
- Messages
- 7
- Vehicle
- T5 SE 180
I've owned a VW Caravelle for over 10years and had always planned to buy a California when the kids left home. Last October I rented one from the lovely people at California Scotland it didn't disappoint in any way and led to me to buying one slightly sooner than I had planned. However, the one thing which did prove a challenge was getting up top! The problem was a total lack of anywhere to put your foot to get a leg up when the front seats are reversed and, invariably, I ended up nose into the mattress as somehow I made it up there. I wanted something which would be easy to use, could easily be put out of the way when not in use and didn't cost a fortune. It also needed to have minimum chance of causing any damage. I've ended up creating a ladder, albeit to use only one step, from 32mm solvent weld waste pipe and 2 broom handles, total cost about £20! Silicon sealant was used to fill part of the gap between the broom handle and tube to increase the stiffness. As the ladder is used in a fairly vertical position the lateral forces are quite small, I weight about 90Kg and it's perfectly strong enough for me. When not in use it is just laid along the centre of the mattress and the roof closed, it is just held in place by a slight compression of the mattress. I did create a prototype using 40mm waste pipe and aluminium tube which was significantly stronger but was tighter in the roof although I could still push my hand under it.
![image.jpg image.jpg](https://vwcaliforniaclub.com/data/attachments/10/10316-f0ee7155a0dfe5cfdd15a102c9f76cc3.jpg)
![image.jpg image.jpg](https://vwcaliforniaclub.com/data/attachments/10/10314-97ccd6ee0723c3e504612c6e7ad2154f.jpg)
![image.jpg image.jpg](https://vwcaliforniaclub.com/data/attachments/10/10315-71eebed802d9810555e2a8b92f0bb4cd.jpg)
