Error Codes for the VV Cali
John
John
West Sussex
This was posted on FB discussion board so thanks to Cliff D
Error Codes for the VW California (for VW Technicians)
Push & turn the reset button for 3 seconds.
Turn the rotary/ push-button on the display menu diagnostics,
Select the display menu for VW diagnostics
A flashing icon on the display unit is for camping equipment indicating a fault in that system.
The code is a four digit display.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water fresh water
6 = 6 = Outside temperature outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Read more: http://www.vw-california-owners-forum.c ... z1ffncfo8G
I think these instructions are for the new computers. To access the diagnostics menu on my Cali (2008) I have to hold both the rotary dial and the menu button simultaneously for about a second.
Can anyone enlighten me on what error code 7001 7001 interrupt input interrupt input D + actually means?
I disconnected one of the leisure batteries and noticed this code some time later (after the battery was reconnected)
The code cleared and everything seems fine
Many thanks!
Many thanks!
power lost
Kind of obvious now you've said it!!
Panic over - thank you very much
power lost
Hi Loz
I just used your excellent instructions to disconnect the 3 batteries to change a roof sensor. When I had finished, I reconnected in reverse order that I had done them so I reconnected the seat battery then started then boot battery. This through our error 7001. I’ve just looked again at your instructions and you reconnected the starter last. Is that important?
I’ve got the flashing G symbol now so I’ve plugged the van in and fingers crossed that should fix the code.
I was just wondering if I had made a big error not doing the starter last!?
Hi Loz
Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Try Roof/Heater or Fridge
Not that important, I would turn off the Control panel (press the off button twice) then turn it back on.
There’s an odd quirk with the “Roof Open” problem which is that the control panel won’t turn off.
Unplug the Control Panel or pull the fuses.
Before you ask, I don't know where the fuses are on your age vehicle. Sorry.
Ok thanks. I unplugged the control model.
California John
v-tec
v-tec
Smalls74
P
capt kirk
capt kirk
skinnywhippet
skinnywhippet
skinnywhippet
