R
Roadiesean
Hi
I’m having a problem with my sliding door which won’t open with the inside or outside handle. It’s a manual door. So, the plastic collar that holds the bar that opens the rear part of the door sheared off so I replaced it thinking it would sort it which it has but it will break again immediately because the element of the lock that drops down before the door unlocks with the handle can open it.
The photo I’ve attached shows what happens when you drop the lever with your finger (it then opens perfectly). Obviously I’ve never seen this in action when it isn’t broken so I’m guessing but I feel like something has broken in the drop down element.
Anyone got any ideas or do I need a whole new lock ??
Sean
Sean
