![Borris](/data/avatars/m/10/10155.jpg?1445071610)
Borris
Having spent several weeks plucking up the courage, I've just spent today hard wiring a Nextbase 522GW dash cam and rear camera. The dash cam was no problem at all however routing the wiring to the rear camera above the windows on the N/S of our Beach was quite a challenge. Anyway that's another story as its now done. Thanks to my new kit of trim tools, nothing got broken either. Result!
![20191208_111330.jpg 20191208_111330.jpg](https://vwcaliforniaclub.com/data/attachments/51/51671-8eca48973b3b26bce1e899f803e9c773.jpg)
It's all now up and running but alas there is still one element of this fit that I have still to resolve. So far, I have run the rear camera cable back down the upper nearside and through the rubber umbilical tube between the body and the tailgate. All the trim in the van is now back in position. However it's the tailgate that I'm still having issues with. Accordingly, the cable and rear camera are now temporarily fixed to the interior trim above the boot opening with the rear most end of the umbilical still not re-fitted.
It was my intention to route the cable with its female jack plug end, from the rubber umbilical tube and then into the inside of the tailgate frame pressing to a point above the centre of the rear window. The end of the cable would then out thought a suitable grommeted opening in this internal metal tailgate pressing where it would mate with the male jack plug of the rear camera cable. This camera cable would then pop out from under the lower edge of the tailgate upper trim where the attached camera would be stuck to the middle top of the rear window.
I have two problems:
1. I need to remove the upper internal tailgate trim and so far it has resisted all my attempts to remove it. I have a diagram of said trim detailing the fixings. Is there something I'm missing?
2. Even with the trim removed I'm not certain that the tailgate frame pressing has a suitable opening to bring the cable through. I have seen a photo of the top internal pressing of a standard Transporter van tailgate and there didn't seem to be any suitable openings. Can anyone advise? I may have to drill a hole in my nice shiny new van.![Banghead :headbang :headbang](/data/customsmile/banghead.png)
If someone has fitted a rear camera in this manner I would appreciate any advice you could offer.
Many thanks
Paul
Many thanks
Paul
