![Robin Brooke](/data/avatars/m/9/9954.jpg?1593264543)
Robin Brooke
Extended sabaticaal pursuing a passion to climb
- Messages
- 108
- Vehicle
- T5 SE 180
Hi All,
This morning on startup I noticed a flashing light on th Control Panel, showing the roof icon with roof up flashing.
![thumbnail.jpg thumbnail.jpg](https://vwcaliforniaclub.com/data/attachments/80/80546-7070da1c2e340a6c7bb927280428b976.jpg)
I got out and looked and could see the roof appears fully closed - see below.
![Untitled.png Untitled.png](https://vwcaliforniaclub.com/data/attachments/80/80547-c09fd5e28c4de9f884306309786b7fc8.jpg)
I tried to open/close the roof using control panel and it starts then cuts out after 1 second. Same everytime I try there after. Then try to close and makes close noise then cuts out.
I look in the manual. California Supplement.
Its says this Flashing Light means the roof hydraulic system is overheating, it advises you should wait a few minutes and try again (strange as haven't been doing anything to heat the system)...
Anyway I wait 10 minutes try again, same problem. Repeat x2.
I search the VW California Forum. Some posts suggest:
1. Restart the control panel - done, no change.
2. Look up error code on Control Panel.
![thumbnail2.jpg thumbnail2.jpg](https://vwcaliforniaclub.com/data/attachments/80/80548-007d2f08bd34c1fad3846ce276269a19.jpg)
![thumbnail3.jpg thumbnail3.jpg](https://vwcaliforniaclub.com/data/attachments/80/80549-24efc880b568c56cb0d026ba305a0975.jpg)
![thumbnail4.jpg thumbnail4.jpg](https://vwcaliforniaclub.com/data/attachments/80/80550-503fe74d29fb49766da3109c060f653e.jpg)
I get error code 1000. I try to press escape for 5seconds but doesn't clear the code, just back to main menu.
Has anyone had a similar experience? And/or know what error 1000 means?
I'm guessing I will have to visit a dealer, but I'd really appreciate any insight, experiences, info that will help me manage the interaction with the Dealer, or if you have had the problem and found a solution.
Thanks in advance!
Thanks in advance!
