![R_Sargeant_CH](/data/avatars/m/30/30668.jpg?1642103820)
R_Sargeant_CH
I know what is it.Prob gotta be over 60 to know what it is![]()
I’ve had one a couple of months. It does produce a good shot - on the other hand it’s quite finicky and needs a good, consistent grinder to get the best out of it. Not hard to grind a smidge too fine and end up choking it. Everything has to be properly pre heated or you end up with a lukewarm shot. You’ll need a small scale to get the dose right too (or pre weigh all the doses into ziplock bags!).I need an espresso in the morning. This on my to-buy list
View attachment 91591View attachment 91590
I bought a 1Zpresso grinder too. The one with the Italmill burrs. Currently my go to for drop coffee at home as my Londinium espresso maker is still in storage. I bought the grinder primarily for camper van duties, but it works so well I use it all the time.I’ve had one a couple of months. It does produce a good shot - on the other hand it’s quite finicky and needs a good, consistent grinder to get the best out of it. Not hard to grind a smidge too fine and end up choking it. Everything has to be properly pre heated or you end up with a lukewarm shot. You’ll need a small scale to get the dose right too (or pre weigh all the doses into ziplock bags!).
My van camping setup is the Picopresso and a 1Zpresso hand grinder. 1kg beans from Syra in Barcelona. If moto camping, it’s an aeropress and a smaller grinder that fits inside it.
I don’t remember which model mine is, but is geared towards the finer grinds. I should try it with my home machine! It does suffer a bit from retention around the burrsI bought a 1Zpresso grinder too. The one with the Italmill burrs. Currently my go to for drop coffee at home as my Londinium espresso maker is still in storage. I bought the grinder primarily for camper van duties, but it works so well I use it all the time.
I can vouch for the 1ZPRESSO grinders, not cheap but worth the mone.plus
= Coffee Nirvana![]()
Agreed. The engineering is second to none and trounces the Comandante on price. The one I have as the Italian made Italmill conical burr set. I use it even at home its so good. Only downside is switching from pour over to espresso. The settings aren't intuitive and 1 or 2 clicks can make a noticeable difference. I keep it dialed in for espresso.I can vouch for the 1ZPRESSO grinders, not cheap but worth the mone.
