A bit long but honest and personal review of our coast.
calibusje
calibusje
T6.1 Coast 150
A review after our first big trip with our new california coast; it has been in our possession for 3 months and after some commute and a short and this journey (18 days in France) has now well more than 7000 km (4350 miles). Please note: we compare it with our old T4 westfalia california from 1991 that we traveled with for 10 years. Of course we also take into account that it was brand new and… a T6.1 with its completely modified electronic system (harness/ wiring) and the minor (and major?) inconveniences that have been mentioned before in other treads.
What we wish we didn't have before: more horsepower because we like to drive in the mountains, so the now 150 versus 78 does this hands down. Air conditioning! after 10 years without we’ve have had it and the 3-zone (but also much more expensive) air conditioning is super. Better brakes: the old T4 had drums in the rear and especially in the mountains and on hot day this could cause problems; now we have disc brakes all around and the ones in front are the enlarged ones (ours a 5 seater and they have those). Also: certainly more storage space. Seats in the tailgate, outside table in the sliding door and the inside table on a rail on the kitchen block provide more general storage space.
What we didn't want to lose: the maneuverability and the maximum height of 2 meters. Check, is so.
What did we have and what we wanted to keep as much as possible, although I knew it would not be obvious: nostalgia while traveling but also just by looking at it. Well, the colour ascot grey gives me the feeling of an older colour (even if it is new) and to me the T6.1 looks a bit more nostalgic which I think is successful.
The layout is like our old one and therefore very familiar. No secrets for us inside… unless the control panel because that takes some time and practice, but once you know some basics, it's not that bad: level of clean water only appears correctly on the screen after a while; wastewater always shows something, but when it is really full, it shows that too. The leveler is a good addition: we used it every night and it works perfectly: you choose your spot and if it doesn't feel level, check the leveler and then you drive on a ramp if necessary. Easy. But what about that light at night when your fridge is on and also the white lighting in the control knob? Solution for now: cut dark paper and you can just slide this between screen and plastic housing before going to sleep: now this is dimmed and no longer disturbing (I will make this in foil). The curtains for the front window do their job well but are not completely blackout but we don't mind this -yet- (maybe we'll buy an indoor blackout, we'll see). We also used them regularly to prevent the sun from clattering directly on the dashboard and steering wheel. The roller blinds all around go up a bit and let in some brightness but over time this got better and now they usually stay down nicely during the night. Above: the three windows that can be zipped open in the bellows are good to make -and keep- it somewhat manageable for sleeping. The children thought it was ok (we had exceptionally high temperatures in recent weeks). We have the panorama window in the front (and why not: for that price you didn't sew in a zipper yourself :D ) and we already used it, but not as much as we thought; rather to let in some fresh air when it is a bit cool in the evening. Sleeping downstairs: in high heat, certainly sleep with your head to the front of the vehicle and with as many fly screens and/or the extension hook in place as possible.
The kitchen unit: the sliding doors are a huge improvement over regular doors and the rest works as it should: water supply and drainage ✔️ cooking on gas is faster than the methylated spirits we had in our westfalia, but the grids already look quite used and that's a pity. Fridge is a blast and everyone knows that: you make ice cubes in it yourself with such a bag that you fill with water. Big enough for the four of us. It did fail once: was off; so keep an eye on it, literally.
Back seat: finally two three-point belts for our children ✔️ and the sliding box underneath is spacious but could use a carpet or something in it to counteract the noise in it (next project, I'll cut one myself and also for the sides). Shifting the couch is easy, although you have to position yourself in the middle and far enough back and then like everyone else does: that's how it goes smoothest. Sleeping on it is no problem if you put something on it that is best for you; for us, the upper mattress from vw itself is good enough.
Opening the manually folding roof (coast) is simple, but closing takes some practice and does not always go smooth: with us, the side of the kitchen unit goes the fastest. The other side takes some pulling to pull the roof down to get the piece over the hook. Just do it in a few steps: roof down, sit in one in front chairs and roll up the cloth on the opposite side and then pull the roof all the way down so that you can hook the piece over the hook and clinch it. Then the security clip on it. Then you move and do the other side. At last slide the shutter and make sure that it goes smoothly without anything getting in between when closing. All in all doable and glad I don't have an electro-hydraulic roof. What can be seen after a week of use: the rubber comes out of the rail at the top corner of the bellows on the kitchen unit. This will be shown to the dealer and will probably be glued. The bellows also has good blackout properties and is made of good material (plastic instead of cotton and this is good for the lifespan: cotton and moisture cause mold if they do not dry out properly and this weakens the cloth; the plastic bellows last longer (also dry faster) Our 31 year old westfalia still has his first plastic cloth. Since the T5 california from Volkswagen itself, cotton bellows were used but now plastic again. Good, I'm happy with it.
The bike rack I find rather bombastic in terms of view but good and firm. We mounted a fiamma case on it and no problem with that. We kept the tailgate open with a U-profile on the strut. Sometimes it would stay open on its own, but it's better to make sure it doesn't fall down.
Our tires are Continental Vancontact 4seasons and hold up well (not tested enough under different conditions of course). I have Michelin Crossclimate on the old California and have the impression that these run quieter.
For security, I still have an old bright yellow steering rod (peddle to steering wheel), that's all (or? ).
The dashboard: I think it's very nice and user-friendly. Preferably not too many closed compartments: when you are travelling, I want to be able to quickly put something away or take something. We did not take the digital meter lot, but the multi-media system with navigation and there is something to be said about that: works flawlessly in general, but has its moments: not wanting to connect to my mobile phone, once completely out. Anyway, if everything works, the music playback features and the CarPlay are very handy. I give the built-in navigation 7.5/10, but the old TomTom - in the old bus - that has not been able to get an update for years, I still give 7/10 so quite satisfied with that of VW (you can also enter coordinates). We also have Waze and Google and Maps on our mobile phones, but an old road atlas is with us in a door compartment so ça va, plenty of options to find our way.
The inner floor: rubber mats at the front and I would recommend these to everyone and the standard plastic floor at the back: we had fixed carpet in the old bus and this is a burden to keep clean! Now much better: wipe with the hand brush and go over with a wet cloth: clean.
Seat covers are definitely recommended when you travel and are even indispensable with children.
Extremely handy: socket at the bottom of the front seat: never again a dead mobile phone :thumb
About the driver's seat: this squeaked and creaked from day 1 and this went from settled to constant after a few weeks and became highly irritating. Our dealer has already taken some actions to fix this but it kept coming back after one or two rides without it. We went on a trip and took an aerosol silicone spray with us and after spraying it almost empty - at various times - in just about every spot or hole under the seat, it is now gone :shocked Hopefully for good.
Point of note: why did they put the button to close the doors when you go to sleep in the front of the door? Didn't they have a more easily accessible place for that?
Our bus is fairly standard: a coast in European version (less standard than for example in the UK) but with extras: additional heating, large opening at the front bellows, extra lighting (especially taken for the light points at the top), sliding window in sliding door (a must for us) and a five-seater version (which obliges bigger front brakes and therefore bigger rims. I chose the steel rims because although I like big alloy wheels on others, I just wanted to keep it basic). I already mentioned the expensive air conditioning. Heat-resistant windows that also give less insight: beautiful and will help something I think (the old Westfalia had double glazing. If there will be a lot of condensation we have yet to notice during further trips.) The adaptive speed controller (good system, but still keep an eye out for yourself). We also checked some other things such as the larger fuel tank, rear camera, electrically folding mirrors and fog lights. Diesel heating is about the last I can come up with right now of the options we took. We also use the cali in the winter, that's why. No painted mirror housings and handles. Too fancy for us (just kidding). Honestly, I like the pure look of the coast but like to look at all californias without exception.
Headlights are fine although I now think that I might have better ordered the LED lighting at the front… but I won't know for sure.
Something new that popped up just before this trip: a nasty crackle right from the front window at times, perhaps with a change in temperature and on less good road surfaces. I have to keep an eye on this. What else: in the morning, after a few hours of rain, there were drops of water on the inside of the top trim of the tailgate. I have already seen it pass in one of the many forums or Facebook pages and will look for it.
Do I think it is the quality vehicle that it is sold for? Not really... and I think I know why. But that's for another thread. Do I think it is one of the best small campervans you can buy? Yes. Is it a treat to go on holiday with? Without a doubt.
Drives well, brakes well and consumption: 8.7 l/100 km so far (27 mpg).
In short: even though our savings book is empty, we are very satisfied with our purchase!
The bus gives us the feeling that we are on the road with a firm update of the old one and that is all we wanted.
I know: it is all a bit mixed up and maybe it doesn't all sound very English, but I wanted to write this all down anyway and hopefully it pleased you reading it.
Greetings
Calibusje
Great to read you finally have your new Cali. Looking forward to reading more updates on your experiences with the T6.1 Coast.
Nice review, thanks for that! I have pretty much the same experience with my coast.
I'm kind of glad I'm not the only one.. :) Btw, have you (your dealer) tried tightening the seatbase bolts? That will be my first action, when I get some free time.
Oh and regarding control panel lights: the small orange lights (for fridge, hook up, etc.) don't bother me, since they are quite dimmed, but the large knob light is pita. But i think I have found a solution for the knob light: if I lock the vehicle with the car remote after activating camping mode and after that don't use the control panel, the knob light stays off. You can lock and unlock the vehicle several times, before going to bed we lock the vehicle from the drivers buttton ofc, and if you don't activate control panel after last lock with remote key, the knob light stays off.
Tightening the front seat bolts were the first thing they did, then the squeaking and creaking came back; then many points at the bottom (including the turning mechanism) were injected with silicone spray. Everything came back. Then a seat from another California was mounted: two squeak-free test days. My seat returned (with squeaking and creaking) and a new lower part was ordered. After mounting it and a few rides… again :rolleyes: It also got worse: from now and then to constant squeaking and creaking. Now gone and hopefully it stays away because it was really annoying.
I must say that they tried to help me with that.
With me the orange icons are brightly lit and I don't know how to dim them; this could already help a lot. The white ring of the button does not go out during the night with us, strange. Even though we no longer operate the panel. We also put camping mode on. We don't close the cali with the remote when we're in it but with the -poorly placed- control in the left door. This is how I saw it at YouTube / California Chris I guess.
Thanks for thinking along.
Brilliant review.
For the draw, and the cupboard shelves, we've lined with cheap roll anti slip matting. It comes in different colours, so black on the dash, door pockets and storage draw, and cream in the cupboard shelves.
A fun review and loved some of the words you used - much more interesting than I would have chosen. Bravo for writing so well in a language clearly not your home one.
I'm going to add one more -rather negative- thing: almost every, even cheap, folding chair has plastic pieces at the bottom while those two from Volkswagens in the tailgate look after a few weeks as if you bought them second-hand and well used. Not only deep scratches but also firm pits. Regrettably.
By the way: Before our trip, I wrapped the pieces that touched the ground with heavy-duty paint protection tape as precaution :rolleyes:
To end on a positive note about the chairs: we can sit on them for a long time and the fact that they are stored so well in the boot lid is still a great asset of the California.
Doesn’t that switch the alarm on?
That’s what I think also; when in the vehicle, you close with the -poorly placed- button on the drivers door, like seen on several YouTube videos.
Of course it turns the alarm on, but it also switches control panel knob light off, which stays off even after again unlocking the vehicle - until next time you activate control panel.
I wouldn’t want the alarm on whilst sleeping though…
Excellent review.
I’ve had an ocean since Jan and a T3 high top before that which had loads of storage in the roof. Fortunately I’ve not encountered the squeaks and leaks in the 6.1…..yet. It took us quite a while and some long and short trips to learn how to use it and adapt to its space limitations and if we had hired one for a weekend trial I doubt we would have bought one as that learning / conditioning period takes some time. But it’s great to drive and has some very good features. It also makes a very good everyday car but for me it’s not a fetish object as many here make out and it’s good to read this useful critique.
Yes, I understand what you mean: for us it is the new upgraded version of our old T4 westfalia and initialy, I've bought that one because of the bed length: I am 1m92 and the bed was long enough. And it was cheap.
Traveling with it revealed the benefits of a pop up roof (for us anyway, I understand that others may not prefer it) and the versatility and agility. So now we have the t6.1 coast and I am a bit disappointed in the quality of the vehicle such as the squeaking and creaking front seat but now especially the front window which makes a nasty creaking sound as if it could burst at any moment. Bizarre. This is also getting worse every time.
This is also my every day car and I wish it was a bit more quiet inside (all that squeaking and creaking) to have that quality feel it could have.
Anyway: for travelling it beats a lot of big white whales and for me -each his idea about that of course- it is one of the best campervans to make your travels with.
Dry PTFE spray is your friend. I spent 20 mins going round the van with this gear when I got it, windows, kitchen runners, bench seat mechanism etc...
No need to stand for the creaks.
The dashboard: I think it's very nice and user-friendly. Preferably not too many closed compartments and compartments: when you are travelling, I want to be able to quickly put something away or take something. We did not take the digital meter lot, but the multi-media system with navigation and there is something to be said about that: works flawlessly in general, but has its moments: not wanting to connect to my mobile phone, once completely out. Anyway, if everything works, the music playback features and the CarPlay are very handy. I give the built-in navigation 7.5/10, but the old TomTom - in the old bus - that has not been able to get an update for years, I still give 7/10 so quite satisfied with that of VW (you can also enter coordinates). We also have Waze and Google and Maps on our mobile phones, but an old road atlas is with us in a door compartment so ça va, plenty of options to find our way.
Our bus is fairly standard: a coast in European version (less standard than for example in the UK) but with extras: additional heating, large opening at the front bellows, extra lighting (especially taken for the light points at the top), sliding window in sliding door (a must for us) and a five-seater version (which obliges bigger front brakes and therefore bigger rims. I chose the steel rims because although I like it on others, I just wanted to keep it basic). I already mentioned the expensive air conditioning. Heat-resistant windows that also give less insight: beautiful and will help something I think (the old Westfalia had double glazing. If there will be a lot of condensation we have yet to notice during further trips. The adaptive speed controller (good system, but still keep an eye out for yourself). We also checked some other things such as the larger fuel tank, rear camera window, electrically folding mirrors and fog lights. Diesel heating is about the last I can come up with right now of the options we took. We also use the cali in the winter, that's why. No painted mirror housings and handles. Too fancy for us (just kidding). Honestly, I like the pure look of the coast but like to look at all californias without exception.
Greetings
Calibusje
Very interesting review, thank you for sharing.
For the locking at night I just experienced the same and was going to ask: is this the only way to lock the van at night? If so, pretty strange!
Anyone any tips for how to work around this? I was thinking of either a) a long pointy stick, or b) asking an auto electrician to add an extra button somewhere more central.
Thank you for the response; I am also thinking of having a switch built into one of the free boxes in the dashboard.
Yes, true: I also used such spray a lot. It’s now just that freaking creaking front window screen…
Should I spray around it with it? :Nailbiting
Hard to know what the creaking bursting noise is, but it can’t hurt?
Where did you spray on the seat base? Mine is doing it too…. Going to need to take a bottle when we leave on holiday next week…
The following helped us: you first remove the plastic piece (needs a tug to pull out the lower large pins, but it works well): first picture. Then on the second photo I showed in yellow where I sprayed. In the gap but also on and around the white rounds. There are also black round catches and those also sprayed. Basically everything you see that you think can squeak or crack: spray ;)
Succes!
Glad it not just me that struggles to lock the van on a night; with ladder between the two front seats it’s near impossible to reach over to press the lock button.
I now end up just removing the front headrests when I’m parked up for the night to make it a lot easier to reach over.
I’ve been looking to see if I can get hold of just the two drivers door lock/unlock buttons from a breakers (at the moment I can find only the whole panel to buy with the all window switches and mirror controls) and get them mounted somewhere in the b pillar that’s easy for everyone to reach
Far easier solution - just buy a Grand California, VW put a locking button next to the bed.
Cheaper solution - buy one of the GC locking buttons to install, in the GC its a stand alone button, I'll take a photo if I get a chance tomorrow.
Andy, great idea. If you are able to get a part number if possible please. I am building a remote lock (thanks to the T6 forum). If parts available, it may just look the part. :thumb
I can’t get a part number without the risk of damaging the trim but if you have access to a parts diagram for a GC this is on the rear face of the C pillar at the end of the kitchen.
