Initially, water was appearing in the drivers footwell. I pulled apart the trim in the lower dashboard and traced it up to the A-pillar. So I removed the trim on the pillar and traced it up to the top corner of the windscreen. Thinking I had found it I had the windscreen removed and the seal replaced; but this wasn’t the problem. As mentioned earlier in this thread the water was finding it’s way through a tiny overlapping bit of metal above the windscreen. So I pulled the headlining back and found the drain pipe, which is connected properly and draining properly. I don’t think the drain is leaking, although the leak is somewhere nearby. The rubber grommet in the roof where the electrics disappear into seems fine. There is a small amount of corrosion but nothing noteworthy. If I open the roof and pour water into the drain it works properly. If I block the drain the water doesn’t go anywhere. I’m struggling to trace it any further because of access to that piece of the roof.
Sadly not. I’ve been busy with work, so for now the van has a cover over it and is chocked up at the front which is working to prevent water ingress. The craziness is that with the roof up, when I pour water into the roof channels, the water drains correctly and nothing comes inside. But just a bit of rain and van seems to deposit the whole lot inside. I would need a tiny camera to trace it further now.Did you managed to trace it? Have a similar issue.
This is the same as mine. I still don’t understand it. Roof down, leaked like crazy but roof up, full downpour, didn’t leak. Water does not seem as predictable as you’d think.Sadly not. I’ve been busy with work, so for now the van has a cover over it and is chocked up at the front which is working to prevent water ingress. The craziness is that with the roof up, when I pour water into the roof channels, the water drains correctly and nothing comes inside. But just a bit of rain and van seems to deposit the whole lot inside. I would need a tiny camera to trace it further now.
Glad you got it sorted looks like a good job.I wanted to report back that I’ve finally fixed this. It’s been quite a journey, from me trying to find the problem, VW spectacularly failing the find the problem and finally finding a good independent garage who could fix it.
So, here is my report. I took it to Jason and Mitchell at Dub Works in Petersfield in Hampshire. They found that the front spoiler was lifting and had corrosion under it.
The water had been getting in through little holes along the back edge of the front spoiler.
That’s all been fixed and they’ve added some invisible drain holes under the front of the spoiler in case water gets in there again.
This van has been really good and had no real visible rust in the roof so it’s been quite an eye opener that this was all going on under that front spoiler. Hope this helps someone else.
If you've had the replacement plastic cowl fitted over the ali roof corrosion check the mastic seal all around it for cracks, had my plastic cowl replaced under warranty by VW after 2 years due to leaks, see photo, zoom in ...@pilot_mark I have a horrible feeling I'm in exactly the same space, so interested to know the cost. As above I've tried sealing around the grommet with to no avail (one side was already fully sealed anyway, and like yours it doesn't leak with the roof up). Still convinced it's getting in somehow at the back edge of the front spoiler. Hoping to get a couple of days off work in next couple of weeks to remove headlining and get the boroscope in there to prove it, but if I can't seal it up myself then may need to go down the same route as you.
Thanks - After my first round of investigation, that’s exactly where I thought the problem was, and my seal was cracked with gaping holes. So I completely removed to old seal material and replaced it with fresh sikaflex, and replaced the protective tape. That was last March, and it seemed to fix the problem. But in September it started leaking again (same symptoms). The (new) seal is still looking fine, albeit I’ve tried adding more sealant anyway, but to no avail. Hence now trying to find where else it’s getting in. I did actually find another small leak in the sealant around the side of the cowl, but have plugged that too and it’s still getting water in.If you've had the replacement plastic cowl fitted over the ali roof corrosion check the mastic seal all around it for cracks, had my plastic cowl replaced under warranty by VW after 2 years due to leaks, see photo, zoom in ...
Glad you got it sorted.So, removing the headlining allowed me just enough space to get the camera deeper into the cowling, and film the water coming in and pooling. And with a bit of trial and error, I found the source....and guess what?.....it was exactly where it was the first time, and where @KGCali suggested and where @pilot_mark mentioned: the seal along the rear edge of the cowling repair cap.
This leak was at the far right of KGCali's photo above (where the roof line 'dips down') and along a little. So I had fixed it a year ago, but my seal had developed another split. It was barely noticeable with the naked eye, and the extra layer of sealant I applied back in the autumn didn't go far enough to cover it. I've now removed the leaking section of the sikaflex and re-applied, and now all appears fixed, with headlining reassembled.
Whilst the headlining was out, I did check the two bolts that (I assume!) hold the cowling on. Neither were what I'd call 'loose', but I did get a fraction of a turn on; maybe 1/8 to 1/4 of a turn on the passenger side, which is the side that was leaking. No idea if that will make any difference!
Hope that helps the next person...
Hi all, thank-you as this post has been so helpful as we are experiencing the same issues on our 2012 T5 Cali. Tried much of the above apart from taking to Petersfield VDub as we are in the Midlands, but still leaking. A couple of questions please:Glad you got it sorted.
It's a shame VW didn't use a rubber seal around the replacement plastic cowl as so many users have had issues with the sealant splitting leadings to leaks
Where does the leak exhibit itself inside? Is it above the door/roof handle like ours?
Thanks for such a quick response! We get some water here too... but it gets wet in the ceiling lining around the door handle above the door first we think! we'll keep trying... we've 'repaired' the sealant in the horizontal joint with the back edge of the cowel like others.. but still coming in somewhere... drains all seem fine! We'll keep trying.For me it was manifesting in the passenger footwell, with a wet carpet. It was only once I removed the A-pillar trim I could see it was coming in at the top corner of the windscreen then flowing down behind the A-pillar trim and out at the bottom, into the footwell. Like others I initially thought it might have been the windscreen seal, but it was actually coming out from between two folds of metal that make up the roof structure, right at the top corner of the window.
Without the A-pillar trim in place it just rains down like a waterfall from that point into the cab, all over the dash and door trim, and usually all over the unsuspecting passenger…!
Sorry can’t help with your second question. Although I tried contacting Dub Works several time by email and phone messages and they never got back to me.
Mine leaked all around the headlining roof handles. The front cowl mastic was cracked in a few places around the cowl, front, rear and sides. As my cowl replacement was within the two year warranty VW agreed to replace it so my 2010 Cali was sent up to Claridges who did a great job and no more leaks but I worry about future leaks in case the same happens again after the next warranty runs out.Hi all, thank-you as this post has been so helpful as we are experiencing the same issues on our 2012 T5 Cali. Tried much of the above apart from taking to Petersfield VDub as we are in the Midlands, but still leaking. A couple of questions please:
Secondly anyone know of a good garage in the Midlands area that might look at this pls?
Hi,Fortunately I didn't get any wet patches around the headlining roof handles, but in searching for my leak I did find a completely separate one where the water was coming in from the side of the cowl. I positively stopped that leak by running extra sealant along the side 'rails' behind the cowling cap, as per post #37 of this thread. I never did determine where the water from this secondary leak was tracking to (and it was much smaller than the 'main' one that was causing the problem), but it's one other area for you to check out.
Non VW.Hi,
Thanks for thus brilliant explanation, I have a 2012 Cali, roof repaired under warranty in 2017 but today water was pouring in down both sides onto the carpet. Looking at the rear of the roof facia I noticed very badly corroded metal and a gap along most of the roof between facia and bodywork, so much for VW making this a proper repair.! Question is who can I trust to fix it properly ?
