![OllieCollieCali](/data/avatars/m/29/29505.jpg?1691875862)
OllieCollieCali
Hi All, I have recently replaced a solar panel on my van that had given up, with 2 x 120w panels (thanks for all the advice from @Californication69 ) which seem to be working great, but it also looks as though the controller has also packed up. I have removed the controller for 30/40 mins to try a hard reset, but still isnt working.
The battery levels have gone up very slowly with everything connected, from 12.5v to both now 13.1v over an hour or 2, but its not showing any input from the solar which it used to. So I am thinking of replacing this as well.
Current controller is a Sunworks PWM 240w 15a dual battery controller which has been fitted on the outside of the rear cupboard which is good to easily see its all working.
What is the best controller to go for to replace this - obviously i will have a hole in the back of the unit to cover up somehow where the wires currently come through. So either a unit i can fit inside the top of the rear cupboard and maybe a remote screen? or I could replace with the same controller again or similar one that installs in the same location? Ive heard MPPT controllers are better and more efficient, and notice these are what most of you have installed.
Ive heard Eperver duoracer / Victron mentioned quite a bit, Photronic universe looks like they do one the same as the eperver.
All the wiring is done already, so hopefully just a quick swap over of controller.
Many thanks in advance!
![PXL_20230826_112702519.jpg PXL_20230826_112702519.jpg](https://vwcaliforniaclub.com/data/attachments/112/112005-3d9884a16fa3c8ab4d9f2669826ca53d.jpg)
