![Morsels](/data/avatars/m/22/22429.jpg?1617395044)
Morsels
I second what GP said, Nigel. May be worth it!For an update on my situation... I recently got my Cali back after another two weeks with the local dealership. The rams were swapped and one was replaced, but the problem remained. On advice from VW Tech, measurements (electrical readings) were taken of the roof switches and compared against another Cali (the readings were similar). Having been without the Cali for over two weeks I asked for it to be returned whilst I wait to hear what will happen next. I fully expect to have a simialr response to Morsels, which is what I/we have said all along, the lights are linked to the roof. I'm not saying the 20cm tolerance is acceptable, but if that is their stance then the roof lights should continue to operate within the limit of tolerance. I joked about propping up my roof with two peices of timber - I've just read a post from 2019 that someone already does this! Very disappointing that this issue has been known for so long, tolerance levels have changed over the years (I've read it was 5cm) and how VW previously rectified the issue by changing the hydraulic pump.
