![FredFlintstone](/data/avatars/m/34/34880.jpg?1686251243)
FredFlintstone
OK, well roof drains are clear so not the issue hence reading many old posts looking for people's experiences, support & inspiration. Incidentally can you elaborate on this please, maybe somethings not sealing for me? ThanksAs stated in the Post you quoted, Blocked Roof Drains. There are 4 roof drains that can block, 2 x rear and 2 x front.
Rear- open tailgate and you see a grommet with a hole at the top R & L. You should be able to see through them, if not flush air/water through to clear.
Front - open roof remove plastic cover over the hydraulic ram, just unclips, and drain hole is at the front below wiring loom entry into front roof panel. DO not try to push wire through. Drain makes a 90o bend within front A pillar and there is a push connection that can easily be disconnected. Blow air or water through with a syringe to unblock. Water runs out of a grommet at base of windscreen into scuttle and hence to the ground via wheel arch.
