connecting to mains via the hook up will not knacker the Batteries , VW charging system regulates the voltage etc. when 80% charge achieved The the charger will go into trickle mode, the Cali batteries love being trickled charged.The Ctek is just to check if the battery needs a charge. Have not used it to actually charge the battery. The hook up cable is far easier but was worried that there might have been some sort of energy management going on in campsites when using the hookup and was worried connecting direct to mains would knacker the battery.
How long on continual use with the floor mounted vw cool box should I expect?
Plenty of cool boxes have compressors now. Alpicool are a good place to start and for comparison.connecting to mains via the hook up will not knacker the Batteries , VW charging system regulates the voltage etc. when 80% charge achieved The the charger will go into trickle mode, the Cali batteries love being trickled charged.
cool boxes are not a fridge, they are not as efficient as a compressor fridge , they remain on 100% of the time , they cool the box contents to a few degrees below the ambient temp,
which means when it’s hot the contents are not cold like a fridge.
I don’t know if the cool box has a voltage guard to prevent the LB being depleted fully ?
I would expect a couple of days use from the LB with a cool box connected , but if you connect anything else or turn on lights etc, that will be reduced proportionally
A compressor with refrigerant makes it a fridge , a fan and heat sink makes it a cool box.Plenty of cool boxes have compressors now. Alpicool are a good place to start and for comparison.
a compressor is only required to pump the refrigerant!
You canny beat the laws of physicsI was about to disagree, but checked and you are right. The things commonly referred to as cool boxes with a compressor, are actually called car fridges and those with Thermo electric, cool boxes.
I stand corrected.
