04S Bellow review poll.
Have you discovered water leaks with your 04S A Bellows?
  • No, but I haven't used the bellows in the rain.
    Votes: 8 13.3%
  • No, but I have only used the bellows in light rain.
    Votes: 7 11.7%
  • No, and I have used the bellows in moderate rain/wind.
    Votes: 4 6.7%
  • Yes, but neither my dealer nor the VW Exec. Office are aware.
    Votes: 5 8.3%
  • Yes and my dealer is aware.
    Votes: 6 10.0%
  • Yes, and the VW Exec. Office is aware.
    Votes: 1 1.7%
  • Yes, and BOTH my dealer and the VW Exec. Office are aware.
    Votes: 15 25.0%
  • Yes, and I have had one or more replacements fitted that now don't leak.
    Votes: 0 0.0%
  • Yes, and I have had one or more replacements fitted that still leak.
    Votes: 3 5.0%
  • Yes, but I have stopped the leaks myself using a waterproofing agent like Fabsil or Aqua Tex.
    Votes: 2 3.3%
  • Yes, and an application of a waterproofing agent like Fabsil or Aqua Tex did not stop the leaks.
    Votes: 0 0.0%
  • No, and I have used my bellows in heavy rain.
    Votes: 3 5.0%
  • Yes, had leaks and rejected the vehicle.
    Votes: 3 5.0%
  • Yes, had leaks and I am looking at rejecting the vehile.
    Votes: 2 3.3%
  • No, but I have a small pin hole/holes so bellows are being replaced.
    Votes: 1 1.7%
  • Total voters
    60
Mine has been in rain for a day with no issues. Several heavy showers with wind and a couple of hours of drizzle (and some sleet!). Bellows production date 18/12/23.
That's Really encouraging for later produced Bellows
Unfortunately, mine are dated 10/01/24 and they leak :(
Van collected 1st week of March.
And we have reports of vans collected later than mine which leak. I suspect the bellows on those will also be later than 10/01/24.
My gut feel still says the root cause of the leakage is either thread size/type or needle size.
All the problems appear to be stitch/seam related.
Unless a complete manufacturing process such as adding a waterproof interlayer or treating with a waterproofing agent has been omitted (seems unlikely with modern QC methods), then the focus must surely be on the interface between the stitching holes and the thread running through them.
I could be completely wrong and at the end of the day VW and their manufacturer/s need to figure out how they could get it so wrong yet again.
I wonder if the temper
(and some sleet!).
Would be interesting to add this as another variable. Termperature. If low enough could the stretchiness of the fabric be reduced and therefore make the points of entrance smaller reducing or eliminating water infiltration? What was the ambient temp when you stress tested the bellows?
Can you also add a small hole by the stitching on the off side (drivers) side window stitching. Apparently there are quite a few of these defects. Having mine replace as I type.
I have a couple of small holes like that in our bellows, but before I treated the leaking seams/stitching with Aquatex, I never saw any leakage through the pin holes.
Apart from the pin holes, did you suffer any leakage?
I agree, they shouldn't be there. I just hope your replacement bellows set don't leak.
It was cold. About 6 deg through the day and freezing at night. The day time temp with windchill was around 3-4 deg C.
I concur with this.
Our first weekend 1 March was sub zero overnight. Lashing rain, no issues.
Second weekend with howling rain in Rhosilli and 1 degree overnight fine.
I noted wet bedding upstairs on the third trip when temperatures were 8 C overnight.
Think it’s time to talk!
Ocean delivered in January 2024. Just been tested by Breeze and they accept it is leaking and needs replacing. No white tag in mine when delivered. PIA
Sorry to hear.
Did Breeze suggest waiting for a replacement or are they proposing to fit one straight away?
An update on the scoring and also to remind anyone who hasn't done so already to cast your vote, or to change your vote if your circumstances have changed..
Also, please vote on this poll if your bellows are 04S manufactured after 9th November 2023, even if you have already voted on the other poll.
33 with leaks.
15 with no leaks.
9 not been out in the rain yet.
No significant change from the previous summary. 69% with leaks after being used in the rain.
Sorry to hear.
They are suggesting waiting until there is a definitive solution from VW and have a list of all customers who are needing a replacement. Mine is leaking through the front zips which is apparently unusual!
I did not test to see if the bellows leaked through the pin hole. There were a few minor issues with my van that needed rework so they changed the bellows at the same time.
Haven’t voted as we have 04S bellows manufactured pre November. Think 10.10.23. No leakages in persistent rain for over 24 hours.
Latest summary :
37 with leaks.
14 with no leaks.
7 not been out in the rain yet.
Failure rate based on responses to the poll is now at 73% for bellows that have been used in the rain.
The fact that the failure rate has increased since the previous summary does not surprise me.
I'm watching the main Leaking Bellows thread with interest to see how many reports of leaking 05S we see.
I think I have added to the poll. Picked up Cali 5 weeks ago,first time in light rain, after 4 hours the seam about 10 inches up, there was water beading on seam , dripping inside. NOT HAPPY Put topper on , have booked the van in on 3rd June for 2 days to investigate problem.
O4S or O5S bellows?
Sorry to hear you also have leaks, but equally sorry to say I am not surprised.
Did you take some photos? These may help if you get any pushback from the dealer.
The trouble as I see it, is that there is still not enough evidence to convince me that the latest 05S version is robust and fit for purpose. I think we have seen one or two reported failures already on the 05S version and they have only just become available.
I'm not in any rush to get 05S ones fitted on my Cali and intend to sit on the sidelines until we get more feedback from owners with the latest version.
In fact, if the Aquatex treatment continues to work as well as it has done so far, I don't think I will be pushing for a replacement at all.
I am still away, when I get back I will go and speak to the dealer before it goes in for 2 days. Yes, I have photos & yes I do think it’s going to be a fight, as the salesman did suggest that they are not supposed to be waterproof & they should be put down in heavy rain as stated in the manual. As i said before, this was light rain & had to put the topper on. I had no problems with MY18 Cali.
RockinNRollin
13K
CatNap
