Rev counter
sidepod
sidepod
T4 PopTop
Chaps,
Could anyone with a rev counter (I have a clock instead) let me know where it red lines in gears?
Standard non turbo 2.4 lump. Let's assume standard wheels and tyres.
Third/fourth, mph at red line. Will it rev out in fifth?
Ta v much.
S.
Approx 4250 rpm is the redline. Been so long since I drove it I can't remember the speeds, but think 55-60mph was around 3k in 5th.
Only time I've taken it near the red line was a 30% hill in Yorkshire an a 25% in Devon
Edit: max power at 3700. That's when all 78 horses amble out of the stable:)
Since that didn't actually answer your question, I found an online speed calculator to work it out... (I realise it's a bit warm for bobble hats)
This does assume that the following gearbox ratios are correct...
(O2B) AYD, CCW, CHP, CRL
  • 1st 3.778
  • 2nd 2.118
  • 3rd 1.458 (1.429 - AYD)
  • 4th 1.029
  • 5th 0.837 (36:43)
  • Final Drive 4.611
  • Overall Ratio in 5th Gear 3.859:1 = Theoretocal Road Speed + 3,000rpm 60mph (97km/h)
Red line is assumed at 4250 (it looks about there...) Tyres are 195/70/15. Kitchen cupboard is full of gin bottles.
Gives:
1st: 18mph
2nd: 33mph
3rd: 48mph (49mph - AYD)
4th: 68mph
5th: 85mph
Good luck getting it to 85mph. I took mine to 70 once on a hill and it scared the bejezus out of me.
Edit: Found the max torque - 164nM (121lbs/ft) + 1800rpm.
Strong work as ever Dan. Please send me a few of the spare hours you appear to have floating around. Currently I seem to be averaging about 27 hours per day!
My bus will happily cruise all day at 120kph (75mph). It'll spin up to 130 no probs at all (81mph). I've always lifted at that point so I'm confident the 21 year old girl will achieve the 85 figure. Max torque seem a bit feeble. Blame the lack of boost for that I guess. Lets hope we never need to drag the skin off a rice pud !
I do like the five cylinder lump It's so sweet. It's happiest at around 115 kph. (38mpg av).
I'd really like to build a new unit for the bus. Balance/blue print everything. Mines covered 365k kilometres, doesn't use a drop of oil and runs beautifully so it's hard to justify taking it out to refurb it.
S.
When I finally got around to entering the world of work I had a couple of conditions. No suits and no having to work really hard... :) (although only the other week I found myself in a suit on the early train to Paris. Bah.)
You've got a good 'un there I think.
Mine was very agricultural, used to make so much noise at 65 and economy dropped after 60 (best I got was 34mpg). Sure the turbo didn't help, but I think we know now that my engine has had a troubled life, despite the almost complete VW service history. I've also learned that the very early vans have a slightly different version of the AAB and the cooling system is different.
Westfalia also varied the base vehicle they used when building the Cali. Gearing could be different, and weight - mine has glass double glazing in all the back windows. They also did a version with plastic double glazing and no window behind the wardrobe (which looks like what you have?), I imagine there's a big weight difference there?
We'll see how it runs after the rebuild (and we're back to NA now as well). Got the case back, that's been skimmed (minor depression next to #3), so it's back with my usual mechanic. Who's hurt his back. Nothing happens quickly in my world :)
Anyway, ought to do some work now...
Have you thought of upgrading the clocks to get a rev counter? I've just done my 2.4 Syncro a few months back. I was never sure how much I was revving going up hills. The ratio's are different on a Syncro too so its harder to compare. It all works a treat now after getting the right dials and loom off eBay. Its no good if you want to keep the authenticity of the original dials though.
