sidepod
- Messages
- 6,007
- Vehicle
- T4 PopTop
Out of interest what was/is the definitive problem/fix?
T4WFA eluded to elliptical bore wear?
Every internal combustion engine wears like this to some extent. Simply a case of the forces on a piston during combustion. The piston doesn't travel vertically but elliptically within the bore.
Unfortunately in the case of the 180 engine it seams VW failed to manage it adequately.
So is the fix a different ring set? A more robust oil control ring ? Different bore coating ? Different machining tolerances?
I know VW replace the engine but that's just the easy and most cost effective solution.
What is in the new engine?
