![briwy](/data/avatars/m/4/4974.jpg?1477856088)
briwy
I thought the DSG box had to have an oil change at 60k not 40?
Not the gas. The interior heat exchanger and de-humidifier get contaminated/wet and provide an ideal breeding ground so the air blown into the cabin can be contaminated so that all the air ducting etc:. gets contaminated also. Periodically the system should be cleaned. Normally an aerosol containing a disinfectant blown/sucked through the system.I don't want to send the thread off topic, but it's a closed system isn't it? The air is blown over sealed pipes? If that's the case, who cares if the gas is full of bugs? Bugs in the general ventilation system would be there even if no air con is fitted? I get the lubrication of the seals.
Computer says 40,000, same for the Haldex. Maybe subsequent ones have a longer interval as the 1st change could be sooner as the filter might requiring change due to picking up manufacturing debris and I don't think the filter can be changed without changing the oil.I thought the DSG box had to have an oil change at 60k not 40?
How many miles will YOU cover during the term of the Service Agreement?I am confused. If the items serviced are 'service items' required by VW to be serviced, in other words mandatory, then why would they not be covered by service agreements such as that sold at time of purchase of the vehicle?
Interesting. No mention of DSG filter or Haldex but they do mention ATF, Automatic Transmission Fluid.I purchased the prepaid VW service plan when I collected the T6 in June 2016. My understanding is it includes 2 minor and 2 major services and 1 mot as per the VW service schedule. Total cost was £214.80 including all engine & gearbox oils & fluids and brake fluid required as per the VW standard servicing schedule. It is valid for 8 years and/or 80,000 miles.
I belive the same plan is now £864 but the terms and conditions are still the same (Feb 2016).
WHAT IS INCLUDED
2 x INTERIM services
We’ll make sure to check the:
• Wipers, washers and fluid level
• Horn
• Lights
• Condition of the front and rear lamps
• Instruments
• Battery ‘magic eye’
• Coolant level and anti-freeze strength
• Condition of visible drive belts
• Brake fluid level
• Power-assisted steering wheel
• Saturation indicator on the air filter (if fitted)
• Tyre condition, wear patterns and tread depths
• Tyre pressures and correct them if necessary
• Brake system for leaks and damage
• Thickness of the front and rear brake pads/linings
• Steering and suspension for wear and leaks
• Drive shafts
• Condition of the exhaust system
• Change the engine oil and filter
• Reset the service interval delay
2 x FULL services
• Lights
• Horn
• Instruments
• Washers and wipers and top-up fluid
• Tyre condition and tread depths
• Tyre pressures and correct them if needed
• Airbags for visible damage
• Sunroof
• Tipper system and change the oil if necessary
• Paint and bodywork for damage and corrosion
• Expiry date on breakdown set
• Engine and engine compartment for leaks
• Gearbox, final drive and rear axle for leaks
and damage
• Manual gearbox oil level
• Final drive oil level
• ABS sensor and cables
• Underbody sealant and panels for damage
• Supplementary rubber rings
• Steering joints and boots for wear and damage
• Coolant levels and anti-freeze strength
• Condition of the camshaft drive toothed belt
• Power-assisted steering oil level
• Brake fluid level and condition
• ATF level (automatic)
• Battery
• Idle speed
• Adjustment of headlights
• Drive shaft
And we’ll also:
• Run a vehicle systems test and read fault memories
• Grease the front door check-strap and hinges
• Grease the trailer coupling
• Change the gearbox oil if necessary
• Change rear axle oil if necessary
• Renew the air filter
• Renew the pollen filter
• Renew the fuel filter
• Perform engine basic settings
• Perform a road test
1 x MOT test class 4.
WHAT IS NOT INCLUDED
All non-standard service work:
• Glass, including windscreen glass and head lamp lenses
• Tyre replacement or puncture repair
• Wheel alignment
• Oil, air and fluid top-ups between services
• Maintenance and repair of non-factory or non-standard
fitted items/accessories
• Broken aerials
• Fuel
• MOT (apart from the Buy 4 package)
• Roadside Assistance
• Camshaft belts/chains
• Drive belts/chains
*Please note that general and further exclusions may apply.
• Body repairs
• Any repairs or maintenance associated with
the diesel particulate filter
Damage caused by:
• Negligence, abuse or misuse and accidents
• Food, drink and cigarettes
• Any form of corrosion including pollution,
water, chemicals
• Salt and weather
• Using the incorrect oil or fuel
Correct me if I'm wrong but the T6 only comes with Manual and DSG, which doesn't use ATF.
The whole package is good value if you do the mileage. If not then VW win.
Mind you at 4 years or 80,000 miles there will be a cambelt change which is not included.
Is the service package transferable if you sell?
I have 91,000 kms on my cali 4 motion, 2013 model, reading all the threads regarding cambelts I went to my local Vw in Luxembourg and asked for belt change and water pump. Directed to the service agent,he checked his computor against my chassis number.
No sir, your vehicle does not have timing belt change until 210,000 kms or 10 years, whichever comes first.
Wouldn't like to chance that. Get it in writing then when the belt snaps and wrecks your engine they should pay.
Are you sure he's not looking at the V5 chain engine?
Would seem more likely.......
2nd Service. 1st one at 20,000 was just an engine oil and filter change.If your service guy is correct, it does not surprise me as there should be interim belt condition inspections. However, it does seem an extraordinarily long interval for a service dealer to admit to and if it snapped out of warranty I suspect the repair job would all be at your cost!
As vehicles (especially Cali's) have become more technologically sophisticated with thousands of possible build variations, I suspect VW service dealers have access to vehicle specific maintenace interval data that varies from the generic standard lists in brochures and even service handbooks.
I looked at cost of ownership over 5 years and the prepaid service and extended warranty immediately became a "no brainer" as they say even before you take account of peace of mind, an extra 2 years roadside assisstance and no doubt improved resale prospects.
Not sure if the same offer is still available but I bought 4 x service 1 x mot and 5 year 80,000 mile warranty packages for less than the actual cost of WG's first full service. Excellent value, even at current list prices.
It cost you or VW £726? That's a scary amount of money isn't it?
Is that a normal price for the second annual service?
Can I assume that these items will be covered under the service contract that I have purchased with the vehicle?
This is what VW UK state.I am pretty shocked by his statement,on returm home ,I checked my serviceplan booklet ,supplied with my vehicle,page 19 deals with,multivan,caravelle,transporter and california.
The very last entry on the page covers the timing belt,(zahnriemen und Zahnriemenspannrolle,(nur 4 zyl- common rail diesel motoren).
Alle 210,000 km.
Do you have the service plan booklet in Uk with your new vehicles?
I appreciate your post WG, and I will question this one more time as I am talking with the engineer on Monday. Could you advise the limits in your service manual, if supplied with your new car.This is what VW UK state.
Scroll down to cambelt.
http://www.volkswagen.co.uk/owners/servicing/what-we-check-and-why/cambelt-change
Nothing in the Service Book, all computerised.I appreciate your post WG, and I will question this one more time as I am talking with the engineer on Monday. Could you advise the limits in your service manual, if supplied with your new car.
Reason I posted my comments,are because It would be a shame to spend all that money, if the time limits have been altered for newer engines, and I have always tried to err on the safety side.
