![sidepod](/data/avatars/m/2/2037.jpg?1709621249)
sidepod
- Messages
- 6,051
- Vehicle
- T4 PopTop
Because they can’t be bothered to do it properly.A lot of converters connect one either under the bonnet or under the rear bumper. Have a chat with some
Can help prevent rust longterm if you avoid cutting into the panel. Some older vans (T2,T25, T4) tend to have rust streaks around hookup and/or fridge vent.Because they can’t be bothered to do it properly.
Because it’s not been done well enough.Can help prevent rust longterm if you avoid cutting into the panel. Some older vans (T2,T25, T4) tend to have rust streaks around hookup and/or fridge vent.
Grand California water fill chut is going back of side door when is open. water chut is same look and way open is electric charge connect door.Can’t do that as double sliding doors gets in the way
Yes but you don't have the Flap open and the EHU lead plugged in to be damaged by the sliding door.Grand California water fill chut is going back of side door when is open. water chut is same look and way open is electric charge connect door.
yes can be plug and open - be careful gentle open slide door and not push all way to end when door can hitting plug.Yes but you don't have the Flap open and the EHU lead plugged in to be damaged by the sliding door.
Well the pictures I have just reviewed have the Water filler on the sliding door side and the EHU socket on the non-sliding door side close to the rear light assembly.yes can be plug and open - be careful gentle open slide door and not push all way to end when door can hitting plug.
