andyinluton
- Messages
- 7,251
- Vehicle
- T6.1 Ocean 204 4 motion
I’ve opted for the all in warranty as is a good deal. However the level of warranty cover doesn’t match the original 3 year warranty,
Coverage looks fine to me, I cant see any warranty covering the following & the only difference with the original is the battery. Even that you would be hard pushed at 5 years to argue that it wasn't fair wear & tear.
What is not covered?
Replacement parts and labour will be paid for with the following exceptions:
Routine servicing (all parts replaced associated with routine servicing are excluded) All bodywork, glass (including heated) and seals
Wear and perishable items as follows:
All adjustments, cambelt timing, diesel timing or cleaning
Batteries
Brake frictional material
Bulbs and fuses
Clutch frictional material
Coolant pipes and hoses
CV boot gaiters
Exhaust systems including diesel particulate filters (although catalytic converters are covered for internal failure only)
Non-manufacturer’s original parts or second hand parts
Tyres and wheels
Unencased drive belts
Upholstery, interior and exterior trims
Washer pipes and vacuum hoses
Wiper blades, arms and washer jets
Wiring and connections (including HT leads and aerial coaxial cables)
