![fluff34567](/data/avatars/m/20/20244.jpg?1718132526)
fluff34567
Hi all, I have the T6 factory aux heater with the remote to use it as a parking heater. Sometimes the heater will run for a short period then stop. I notice as the van isn't warm and the overhead display isn't on. No fault codes are stored. I suspect its the leasure battery as the heater will run indefinitely when the engine is running.
After 4 days of not using the van the leisure battery voltage is 12.03v . I didn't check the voltage when under load.
Anyone experienced similar ?
Thanks.
Thanks.
