![MattBW](/data/avatars/m/10/10035.jpg?1578049619)
MattBW
Here to help
I was told when I bought mine that EHU and charger was standard from 2014 T5. I think 2016 they made it an option again on the T6.
Nice one.Can't get access to this guy that was so sure about the charger being absent anymore...
I'm now trying a different strategy. Contacting a different garage and asking them to have the "faulty charger issue" fixed under VW warranty. I have an appointment for end of april.
Are you any further forward?Can't get access to this guy that was so sure about the charger being absent anymore...
Last monday the car went to the garage for investigating the issue (as well as oil service). When I picked it up, I was told there had been an excess voltage error in the computer and that they'd cleared that. I was skeptical at the time, but the guy that read the letter and handed me the invoice (for the oil service) was not completely up to date. Then I tested when I came home. Battery at 12.8. Connected a light to the 12v socket near the sliding door and left it on for 8hours. Measured voltage 12.18. Waited an hour. Measured voltage 12.30v (stabilizing). Then connected hookup all night. Voltage in the morning: 12.30v.Are you any further forward?
Bet it was the Mains plug into the charger. Been mentioned frequently on the SE and Ocean. Pity this isn't part of the PDI check the Dealer carries out.Update:
The issue is resolved! After removing the side panel, they saw that a connector from the charger had gotten loose..
I wasn't there when they did it and didn't get to see any pictures but I believe this must be it. I'll do a test as soon as I have time. Expect to see a > 13v voltage when on hookup.
Finally...
The garage who fixed it gets my Cali's servicing for the rest of it's life. The garage that denied the charger's presence will never get any visit from me again.
Don't think they fall out. They just don't push the plug home. It's the same plug as used on an electric kettle. Never had one of those fall out.Slightly bonkers to me that they haven't changed the design as they seem to come out quite easily.
Yeah but your kettle doesnt have to cope with the state of roads todayI d
Agree. But normally the problem is from the factory. Mine was in the socket by about 3mm. The pins hadn't even connected.Yeah but your kettle doesnt have to cope with the state of roads today![]()
Hello Andy and Vicky,Hi everyone
Currently in France on our first camping trip in our 2017 Beach and getting the “12 volt power is low” message on the infotainment system display.
Still confused by the RCCB thread. Should we be seeing the red bridge or the green one if all is ok with the hookup?
Van is starting ok at the moment but worried that it may not when we want to leave for the UK in 2 days time
Andy and Vicky
But this is a Beach - there's no need to charge the batteries once a month - the leisure battery isn't connected to anything on a Beach unless you have things connected permanently to the L battery.Are you charging your vehicle batteries at least once a month for at least 12 - 24 hours (much better if longer and more often).
Charging once a month is surely only necessary on an SE or Ocean where the fridge is always on and uses up the charge.
Also where are you seeing this?
The message looks like something you'd see from an SE or Ocean, not from a Beach. I don't think there is any message like this on a Beach.
I could be wrong but the Engine Battery is Only trickle charged, once the Leisure Battery is fully charged. The Chargers in the Beach and SE/Ocean are the same. So unless your Leisure Battery was fully charged you might not see a rise in voltage on the Engine Battery when on Mains Hookup.I can confirm that my MY15 Beach charges the leisure battery (but not starter battery) when on hook-up. This was determined by directly measuring the voltage of each battery with hook-up power on and off.
