I know, I'm a retired Intensivist.
Where did you find this please? I can't quite make out the internet address. Many thanks, Judith and ZuluCampiI use a 5m version of this. So far seems plenty long enough for filling up. They are also food quality. I roll it up and it sits perfectly in the space above the gas bottle lid and the bottom shelf of the cupboard.
Out of necessity I ended up using this system and I think I will stick with it. We had taken a fold up water container bought from a chain store, but after I topped up using this I found it had tainted the water and we had to jettison the whole tank
The bucket is the collapsible one I wrote about in another thread. The string on the funnel has a large knot at the top end which slides into the awning rail. Thus the tank can be filled single handed very rapidly.
Shuddycamps,Where did you find this please? I can't quite make out the internet address. Many thanks, Judith and ZuluCampi
You don't need to say "Brandrup" and "expensive" in the same sentence, they both mean the samewe use the 10 litre Brandrup collapsable water bottle using the awning rail attachment to hold it up when filling, it was expensive to buy
What do you use to sterilise the tank when you do your annual clean?I just use the garden hose. Flush it through then fill tank. I use it for everything. I'll even use it for drinking water, but usually have bottled water chilled in the fridge. Certainly use it for cooking and making hot drinks. Normally have to fill the tank every 48hrs, so it doesn't hang around long. Never caused any problems in the past. I sterilise yearly and drain it after each trip.
the problem isnt germs or bacteria - garden hoses leach chemicals into the water which is a long term issue, not anything to do with drinking water quality. it is the build up of chemicals that is the concern.
And the Campsite taps etc: I've seen people washing out their Chemical toilets from them.We use a food graded hose, we also carry it with us and use it on campsites. Even though we do not use our onboard water tank for drinking we do occasionally use it for cleaning our teeth and washing veg. If you knew what lurked in a garden hose you would never ever fill your fresh water tank using it !!
Milton solution. and just follow the instructions.What do you use to sterilise the tank when you do your annual clean?
