Azamat
Hi ,
Our stock AGM battery in our GC600 is not enough for off grid weekends. We still have a warranty and i want to find easy solution of adding some more power
Do you think that i can connect portable power station to cigarette adapter in rear of GC to power refrigerator , lights etc .? . If there is a problem with interaction with existing AGM battery under the bonnet i can switch main battery switch off to isolate front AGM battery.
Does it make sense, do you think it will work ?
There is 10A/12V output on Bleutti power station which should be enough.
Thank you for your response and ideas
Tomas
Tomas
