sidepod
- Messages
- 5,986
- Vehicle
- T4 PopTop
I’d be asking for an appointment with the manager at SMG, tear him/her a new arsehole!
Cowfold. I won't be using them again.Which branch of SMG?
I’m with you there @sidepod these sort of things need calling out. It now appears ok in many aspects of life to rip people off!I’d be asking for an appointment with the manager at SMG, tear him/her a new arsehole!
And a convo with VWCUK and a appropriately worded Google review, might make them buck up their ideas too and perhaps save a less savvy owner from being bent over.I’d be asking for an appointment with the manager at SMG, tear him/her a new arsehole!
Vw Franchised a dealer are measured on the feed back / complaints via VWCV - Let it Fly !And a convo with VWCUK and a appropriately worded Google review, might make them buck up their ideas too and perhaps save a less savvy owner from being bent over.
Maybe there were some costs incurred at the donkey dealer SMG. Plus the transport to the proper mechanics shop. Then diagnostics time. But you're right even if those costs were incurred that still leaves quite a chunk of change for an injector replacement. Maybe there are other parts changed at the same time.Am I the only one thinking that even £1800 seems a lot in the end?
A new, not recon, injector is £350 without any discounts, that sounds like a lot of labour.
Maybe they replaced the set ?Maybe there were some costs incurred at the donkey dealer SMG. Plus the transport to the proper mechanics shop. Then diagnostics time. But you're right even if those costs were incurred that still leaves quite a chunk of change for an injector replacement. Maybe there are other parts changed at the same time.
How many are there on a T6 diesel engine?Maybe they replaced the set ?
Four I assumeHow many are there on a T6 diesel engine?
That is the correct answer. But replacements are only £201 so there has to be some additional parts replaced.Four I assume
I guess an injector could go bad in several ways.I noticed that before the fault was fixed, it was mentioned that the van was burning lots of oil.
"Van was struggling up hills and using a lot of oil but no signs of an oil leak"
Can a bad injector cause that too ?
Has oil usage gone back to normal now @Debcel ?
I agree, a duff injector wouldn’t have any effect on oil consumption. It may however cause a trail of black smoke behind the van which could be mistaken for burning oil.I guess an injector could go bad in several ways.
They’re very high pressure nozzles that produce an optimised spray pattern aimed and timed at a certain place.
If the timing is off due to the valve component being faulty then effectively it’s causing bad combustion in one cylinder. This will certainly lead to loss of power and oil from the exhaust (probably black smoke).
Burning engine oil is another thing all together, blue smoke.
A bad injector couldn’t cause an otherwise healthy motor to burn its own oil.
Yeh a good compression test result is a very good sign of a healthy engine, so Debcel must be very pleased. Maybe the oil loss was just a mistake like you said because it looked "smokey". I did read that a broken injector can wash the cylinder out, thin the oil a bit and cause it to burn off quickly, that sounded a bit tenuous to me though. I also read that some injectors have an oil feed which can escape into the bore, I think that is in more agricultural engines though, but I wasn't sure.OP stated that the indie he used ran a compression test and all was well. Whilst not a perfect diagnosis of a healthy engine, it’s promising.
