W
willbus
- Messages
- 52
Thats strange then.....
This is the circuit. If you have disconnected the Starter Battery and removed the Fuse S, 80 amps then the Leisure and Engine Circuits are separated. If the Lights are still on then there must be a short circuit somewhere.Update. Took out the 80a fuse under the passenger seat. Then disconnected neg and then positive of the starter battery. Lights still on!!!!
I agree regarding VW Sinclair. I use VW South Hereford.I notice your location Welshgas. Im in Cardiff. Do you know any good autoelectricians in the area who might be able to help. I find Cardiff VW not the most useful!
In Hereford. Combined Car and Commercial Dealership. Taken over by Vertu about 18 maths ago. Had my last service there in December 2017.Do you find South Hereford good then? Is that the one in Hereford or Whitchurch? Thanks again
No, that was a Norwegian member.Willbus - it wasn't you the other day asking about the broken towing electrics under the back of the van was it?
A short on the towing socket between the 12v+ and the trailer lights circuit as shown on the photo below could cause the rear lights to come on without using the switch.
Good point, have no idea where that is.To completely power down assuming there is an issue with the BCU, you will need to disconnect all the battery negative leads and unplug the alarm sounder as it carries its own rechargeable battery.
