![soulstyledevon](/data/avatars/m/4/4110.jpg?1443206837)
soulstyledevon
Kennycalifornia
- Messages
- 6,260
- Vehicle
- Cali now sold
If you look on this site it gives all the battery dimensions plus post positions which should help finding a physical Leisure Battery equivalent easier to identify..
https://www.tayna.co.uk/VW-Audi-5K0915105H-Compatible-Battery-P9527.html
I had a browse for leisure batteries and the size of the above 'car' battery doesn't match up to any leisure battery sizes. Looks like you would need to check if a longer and taller battery would fit then you'd have a bigger range to select from.
I found this site which has a large selection with sizes which would be a useful guide as to what's available.
http://www.alpha-batteries.co.uk/leisure-batteries/?p=8#breadcrumbs
This being the closest match. http://www.alpha-batteries.co.uk/leisure-batteries/90ah-xplorer-agm-leisure-battery/
Finally got round to looking at this properly B J G.
Have you ordered this battery from this company? Dimension wise it looks about right. Same Width & Height just 7mm shorter on length. So should fit.
I can't remember, but does the current Beach battery have a vent pipe...?
