andyinluton
- Messages
- 7,251
- Vehicle
- T6.1 Ocean 204 4 motion
I need to lower it a little to get it in the garage (2m ish garage door but with the slight slope I'd like a bit of contingency - especially given the reports from some that their calis are taller than the 1995 advertised.
Mine was at about 2005mm when delivered, after loading it up a few times & using it a bit its settled at about 1990mm unloaded.
Give it a few miles to shake down before deciding what to do.
Also make sure the tyre pressures are right before measuring, if flat you can loose 10mm easily, over filled & gain 5mm.
A full fuel + add blue tank brings the front down a little, water tank affects the back by a little.
