andymcm8
Is this just worn out or related to a roof corrosion repair?The seal around my roof cap is now as much use as an ashtray on a motorbike. Taking it into Breeze Totton later this week for them to resolve
Its a worn our repair. The previous owner had it done when recalled. Not sure when or where as customer care aren't telling me.Is this just worn out or related to a roof corrosion repair?
I don’t think there is any clear tape on that area, the rear of the front, above windscreen, Panel. On the Elevating Roof section yes, but that is a different seal.That looks like they sprayed it with plastidip instead of using the clear tape.
I have clear tape there but only about 6-8 inches in from each side, I thought @Vw guru posted a picture of clear tape there also recently.I don’t think there is any clear tape on that area, the rear of the front, above windscreen, Panel. On the Elevating Roof section yes, but that is a different seal.
Originally there was no tape there. Just painted metal.I have clear tape there but only about 6-8 inches in from each side, I thought @Vw guru posted a picture of clear tape there also recently.
yes he did, see the first photo here; Just announced - T6 recall for roof corrosion beneath the seal
After it happened I checked the pipes weren't clogged up but nope, water ran freely and come out as it should in the wheel arches.That's not too good.
Could it be that they haven't connected the roof drainage pipe up?
although if not, the water would've just drained into the a pillar whilst
stationary.
Yeah this is also putting me off getting another. We are driving to Croatia on Saturday so its going to have to wait until our return. Top tip black electrical tape provides a good temp fixSame problem here. Three attempts last year to seal it and OK until last week. Water now pouring in again. Got the A pillar trims off and headlining down to check that the drain tubes are OK (which they are) so back in AGAIN tomorrow. Ferries booked next month so hope they get it sorted quickly but completely lost confidence in their ability to sort it long term. This and other problems have put us off getting another Cali even though we love the van.
What is that first picture? Need some bigger picture to find out.Done a temporary (or perhaps even permanent) fix today. Filled all the cracks/holes in the sealer round the cover and then covered the back part of the cover with insulation tape. Had the hose on it for about half an hour and then it been raining for a couple of hours and so far no leaks so at least we can use the van. Now got it back in the garage so as soon as it's dried off I'm going to put helicopter tape over the repairs on the rear edge of the plastic cover as well. I think what has happened is that the front seal on the elevating roof has not been put on correctly. The picture shows where you can see the edge of the metal leaving a bulge in the seal. (same both sides) I think this bulge has been rubbing on the sealer on the plastic cover and worn it through as it corresponds to where the cracks/holes are in the sealer. As the elevating roof sealer is bonded on I can't get back in the correct position so it will have wait for VW to sort it.
I never looked at the actual roof as I didn't think it relevant to the leaks but it is the probable cause.
So if you have had your roof repaired just check that the seal is on correctly hopefully to avoid this problem.
Some of the holes in the sealer on the rear of the plastic cover.
The roof seal not on correctly making it bulge outwards.
