Lithium leisure upgrade finally complete
Shadrack
West Wales
T6 Ocean 204
Hi all,
I have finally completed my Phase 3 to my leisure battery upgrade.
Update as promissed.
Phase 1 was to first fit solar:-
Phase 2 was to upgrade the split charge relay:-
Now after a lot of research and help from this and the T6 forum I took the plunge and swapped out my ageing agm’s for a single under seat Lithium from Fogstar.
This battery comes with an inbuilt heater for charging in temperatures less than zero degrees, Also a ten year warranty.
Fogstar after sales have been great with help and information when asked.
I chose the Fogstar 230amp drift, it fits nicely under the drivers seat along with a 200amp fuse and isolation switch.
I ran two heavy duty cables to the passenger seat side in the ducting under the carpets to connect to original battery terminals via two new bus bars.
(I ran two cables rather than just one & earth the neutral under the drivers seat so not to bypass the shunt to maintain correct CP information)
With the newfound space under the passenger seat I added a 1000watt inverter from Renogy. I chose just the 1000w because of physical size and most of my appliances, Air fryer, toaster, kettle, induction hob etc are rated less than this. Also the current drawn from the battery at 1kw is getting on for 80 amps. I would have had to consider even heavier cables if I went to a bigger inverter.
The inverter remote along with a 13amp socket fits neatly behind the passenger seat.
Whilst fitting the bus bars I added a couple of Anderson connectors which connect to the engine agm battery and the leisure battery. I have a victron plugin 30amp charger which I can connect to these if ever needed. This charger does allow me to change the battery profile via Bluetooth should I ever need it.
The Victron solar controller seems to keep the battery topped up pretty well. When this was installed I also added a break before make switch and took a cable to the engine battery. Again via Bluetooth I can change the profile of this between LifePo4 or AGM. This could allow me to top the engine battery via solar should it ever be needed.
The split charge relay replacement was the Victron 30amp smart dc to dc Charger. This can be controlled via Bluetooth. Currently I have switched it off and keep the lithium topped up with solar only. I guess with no leisure load on the alternator I maybe get a better mpg? I can switch this back on for up to 30amp charge whilst engine is running.
Another bonus is I have a spare compartment in the rear now where a leisure battery was installed. I will remove the now redundant factory fitted hookup Charger as the profile Is AGM only.
This added space will be used as a new tool store freeing up space under my rear seat. Also I am carrying 25-30Kg less in weight.
This is the battery underneath drivers seat before finally connecting:-
Under Passengers seat the two bus bars and also the Inverter with Anderson connectors on top.
The Inverter control panel and 13amp socket.
Fogstar app showing battery levels whilst boiling a kettle. (Note current being drawn)
A kettle of 1ltr took 5-6amps out of the battery to boil.
For me to even take on these phases or projects would not have happened if it was not for the people on this forum and neighbouring T6 forum. I can’t thank the help from all the posters enough for such a great knowledge base.
Really big thank you to everyone.
Sounds like a really good installation. Do you have any pictures of the battery under the drivers seat. Would be great to see how you squeezed it in. Great work
Hi Supercharge,
Thank you for comment.
The battery has been especially built for under seat installation, it is a snug fit tho.
I had to remove an unused earth stud standing upright in the middle of the floor. The few connector’s that originally lived there belonging to tow bar electrics etc move to the side of the battery. I did wrap each individual loom connector in foam to check any movement and protect.
The Battery is secured with 3 heavy duty webbing straps secured to the bottom of seat Base. The straps were tightened down with stainless turnbuckles. It is important to have a good fixing on the battery.
the picture below shows it in place with the Fuse mounted on an alloy plate secured to seat base at the front.
The fuse can be accessed whilst the seat is in place should I ever need to replace.
The isolation switch can be operated from the front.
I hope this is helpful for you.
(Battery not connected in this picture as other under seat connections not yet made)
That is a tight fit! I hadn’t seen these batteries before. Great idea by fogstar. That will give you some serious off grid abilities.
An interesting write-up and very informative. I am going a MAN TGE next or I would be doing something very similar.
I would like to point out that we don't have 'neutral' connections in respect to DC circuits, they are either +ve (positive) or -ve (negative) the latter of which is in normal automotive environments connected to the chassis often called chassis ground, earth or in VW wiring terms terminal 31.
Yes I know that older UK cars were wired the other way around with the +ve connected to the chassis.
Thank you for positive comments.
Re the comment on neutral and negative, not really necessary. You will have seen (or maybe missed) in my attached posts that I do use the term -ve or negative. Just a typo if You like.
Good luck with your project.
