Are they any good, those lights.If thats the strip light under the kitchen tops?
I don' have strip light under kitchen top, just the five overhead lights, three above sink unit and two either side of the sliding door,If thats the strip light under the kitchen tops?
I think you push the button on the side of the kitchen behind the passenger seat twice to change it from camping mode to driving mode so it behaves the same as the lights in the cab.
Incae I have got that a bit wrong it's in the supplement with the manuals.
Bout I don't imagine you can do that with the others.
Check that you have the internal light rocker switch by the overhead control panel set to be on for when the doors open. You have potentially turned it off for camping in which case you will have the symptoms you describe.Noticed this thread whilst searcing so bringing it back to life !
I have a question about this lighting. In my 2018 ocean the LED strip under the kitchen panels seems to have 2 modes. The first, camping mode, works as it should. Turn it on and off and can change brightness through holding the button down.
The second mode seems to do nothing (driving mode). I press the button twice and it flashes twice and then the light is just off. If you press the switch to turn it on nothing happens, doors open, locked, shut etc - just nothing. My understanding was that his mode would mean that the strip light should come on when you unlocked the car etc, same as the lights in the front cabin.
In the manual it mentions something about the setting also being controlled from the overhead control panel but there is nothing I can see in the control panel for this.
Anyone got any ideas ?
A couple of us have had problems with this light, it should come on in driving mode when you open the door. Mine had a mind of its own, and was repaired under warranty. It may be the control module or the wiring.Yeah it's on as the two lights next to it come on when doors opened etc.
Tried it so many times, just doesnt seem to work. Very odd !
Sadly have tried that on multiple days now but no response.I guess you have pushed the button twice in 'quick succession' but just worth mentioning.
