@ChainlineBugger! Discovered whilst worrying about fitting new wheels on my drive (when they arrive) , that the toolkit in my GC is ALL missing! I checked for gloop and a compressor before leaving the dealer and they provided them as not present. I didn't realise that the rest of the kit should have been in the under floor location. bottle jack, wheel brace etc. Suspect it was 'transferred' to another crafter when that was missing. Dealer has been good, sales chap was mortified (handed vehicle by Service as good to go) and sorting now so can't knock the dealer response
Wow! I also got no gas hoses and no safety net as a GC680. Dealer is supplying toolkit which I'm happy about. No toolkit at all is ridiculous!@Chainline
Unless you ordered a spare wheel you don't get any sort of toolkit / jack etc on a GC. My Compressor was in the big brown box that had the gas hoses & bed safety net in.
If you have gas heating you should get 4 gas hoses 2x each type. If you have diesel heating you get 2 hoses. Also in the box were things like the manufacturers instruction books for the truma heater, Wc etc I'm sure there was something else in there as well but can't think what it was.Wow! I also got no gas hoses and no safety net as a GC680. Dealer is supplying toolkit which I'm happy about. No toolkit at all is ridiculous!
I think the electric heating & hot water is standard for Uk vans?I now want to know if I have the electric heating or not...will test later. Not on VMS but neither was the inductive charging cradle so I'm not sure its a totally accurate printout.
On the German website there are a few GC owners that have upgraded to 4.2tnne they all seem to have had air suspension fitted to the rear.Why don't VW just take the vehicle to 4.1T. As far as I can see there is no advantage to 3.88t license wise? The Sven Hedin and other crafters can be replated at 4.1T, the speed limits apply as soon as it goes above 3.5T.
For GC680 I'm gonna check. IS rubber mats in cab std. I just read it is and I had to buy those too!On the German website there are a few GC owners that have upgraded to 4.2tnne they all seem to have had air suspension fitted to the rear.
As to speed limits in the UK its an unladen weight of under 3050kg that dictates car speed limits for a Motor Caravan.
Up plating your van makes no difference to your unladen weight so car limits still apply.
Abroad its a different matter, In France for example its the plated max weight that applies so 3.88T = reduced speeds.
I'm sure they are about £60 dealer fit option.For GC680 I'm gonna check. IS rubber mats in cab std. I just read it is and I had to buy those too!
both the GC600 and GC680 unladen weight as std in brochure (90% fuel, 20kg water) are over 3050kg. with std specification. 600 at 3080, GC680 2wd at 3279kg at
Hi Chris, the below is what I will expect - numerous items missing from my previous 2 GC’s on Handover. We are having diesel heating so only 2 gas pipes/straps etc. the gas powered vans get 4.We should come up with a handover checklist, much like has been done for the California T's.
@Jester you have experienced the handover of a new Grand Cali a couple of times, any nuggets of info you could share such that we could compile a check list?
Maybe should be a new thread.
Amazing, thanks Alun, I overlooked the fact that you were a GC handover expert now!Hi Chris, the below is what I will expect - numerous items missing from my previous 2 GC’s on Handover. We are having diesel heating so only 2 gas pipes/straps etc. the gas powered vans get 4.
2 sets car keys
Front window blinds (3) / rods (2)
4 (2?) x gas pipes
4 (2?) x gas straps
4 (2?) x gas collars / straps
1 X Truma key (plastic)
2 x partition boards
4 x sink / shower plugs
2 x remote / keys + 2 x tracker??
2 x water filler cap keys
1 X Tyre inflation kit
4 X Locking wheel / spare nuts
Locking wheel nut key bolt(s)
Instruction manuals / Thetford fluid sample bottle / gas filter
1 X Air con remote control
1 X Auxiliary heater remote control
1 X Rear shower head
Hope this helps?
Alun
Think Alun has covered it,Hi Chris, the below is what I will expect - numerous items missing from my previous 2 GC’s on Handover. We are having diesel heating so only 2 gas pipes/straps etc. the gas powered vans get 4.
2 sets car keys
4 (2?) x gas pipes
4 (2?) x gas straps
Hope this helps?
Alun
I think I did okay but some missing and yeah most sales guys seem to know next to nothing!Hi Chris, the below is what I will expect - numerous items missing from my previous 2 GC’s on Handover. We are having diesel heating so only 2 gas pipes/straps etc. the gas powered vans get 4.
2 sets car keys
4 (2?) x gas pipes
4 (2?) x gas straps
Hope this helps?
Alun
The Truma key is a small black plastic spanner to tighten gas connectors, to help not over-tighten I think, not a great loss if it’s missing. I get the impression that GC awareness is improving at dealers, when we spoke to Terry the other day he mentioned he had a good experience at the Swansea dealer - that was very encouraging as previously we had nothing but negatives about them. They are our nearest. Enjoy your vanI think I did okay but some missing and yeah most sales guys seem to know next to nothing!
I don’t have a Truma key, non locking nut spares not included, no sample bottle and I had to ask for sealant and a compressor but the rest were there!
Big boots!Well these arrived today. Just got to find a local wheel/tyre place that can take the 680 now!
Does your regular ATS or Kwik fit handle our van?
Also booked in for tap…’specialist’ at dealer said ‘we will undertake a diagnostic and assess best course of action’ I said ‘I believe there is a technical note issued and a warranty replacement, reply…. There are backlogs of parts from Germany we may have to replace the water tank. I am now full of confidence…notes I can get the Reich ceramic twist IP rated tap in 33mm next day for ~£70 (I think this is what VW replace with)
I tried to get them in an 18, but Michelin don't make any tyres with a high enough load rating for the GC in an 18.Just a heads up anyone thinking of adding all terrain BFG etc, had them on my joker they are great but awful with fuel consumption.
Especially on tall vehicle like joker/GC I’ve switched to M/S Michelin latitude cross and getting about 6mpg more and they are still not that great for fuel only C rated (still chunky swamper looking).
If it’s just for the look I would hold off until fuel prices come down (hopefully they will or my upgraded 80l tank was pointless as to scared to fill right up).
