clarinetbcn
T5.1 Beach 140
Yes, the Business Edition was a limited edition of the Mulitivan.Actually, the European top of the line was the Business edition.
Starting from €105000 ...
How and what do you do with the contents?I use the same shower tent as mentioned above, installs in seconds and folds up very small. For the toilet part, I have a 5 galllon paint bucket. I then took a toilet seat and cut the plastic pieces underneath to fit the bucket. Very comfortable. I put two plastic bags (between the toilet seat and the bucket) in case one leaks. Another benefit is the bucket can be filled with supplies, usually cleaning supplies, gloves, etc. Works great in a pinch
View attachment 56426View attachment 56427
You must be well balanced if your doing a Betty boo (too much?)Pretty sure my toilet is the cheapest here.
Reusable, easy to empty and no chemicals required.
Just have to remember not to use it to fill the fresh water tank...
And that's why you should never have a curry in a campervan, 5 gallons????!!!!!!!I use the same shower tent as mentioned above, installs in seconds and folds up very small. For the toilet part, I have a 5 galllon paint bucket. I then took a toilet seat and cut the plastic pieces underneath to fit the bucket. Very comfortable. I put two plastic bags (between the toilet seat and the bucket) in case one leaks. Another benefit is the bucket can be filled with supplies, usually cleaning supplies, gloves, etc. Works great in a pinch
I see you have opted for the larger porta-potti. Does it fit in the rear under the bed?
Not with the 2 seat bench but it does with 3 seat bench beachI see you have opted for the larger porta-potti. Does it fit in the rear under the bed?
Good to know. The larger one is slightly more ‘comfortable’ but it doesn’t fit under the Ocean rear shelf. But the 335 does the job.Not with the 2 seat bench but it does with 3 seat bench beach
