Dylan
Member
Hello, help needed.
The main nylon wheel on the lower roller set has broken free on the electric sliding door of my 2012 Cali. I have a replacement roller unit, but it does not slot directly into the track. I think that the door catch unit at the bottom rear of the door opening has to be removed to allow the roller set to be inserted.
Before starting to remove the 2 retaining screws, does anyone know if this is a straight forward procedure? I don't want to make the current situation worse by not being able to re-insert the new roller set and the door catch unit.
Martin
Martin
