Jubilado Tim
I cannot seem to be able to enter decimal co-ordinates into my RNS 510 system. Can anyone advise if there is a setting on the system too allow you to do this\/
I'm not sure what you mean. There is no "setting" available or required.I cannot seem to be able to enter decimal co-ordinates into my RNS 510 system. Can anyone advise if there is a setting on the system too allow you to do this\/
Had this in Ireland ,found google helpfulThanks Welsh Gas. As I understand it co-ordinates are also frequently expressed as decimals rather than the degrees minutes seconds you refer to. The France Passion book we frequently use on our French trips only expresses the coordinates in the decimal system.
Think we used calculator SoupGPS coordinate converter
Easiest app to convert GPS coordinates (latitude and longitude) between decimal and Degrees/Minutes/Seconds gps coordinates format.www.gps-coordinates.net
How did you find google helpful?Had this in Ireland ,found google helpful
